주요 콘텐츠로 건너뛰기
Dell Photo Printer 540 LCD Panel Replacement
필요한 것
  1. Dell Photo Printer 540 LCD Panel Replacement, Case: 1 단계, 이미지 1개 중 1개
    • Rotate the photo printer so that the bottom of the case faces upward.
  2. Dell Photo Printer 540 LCD Panel Replacement: 2 단계, 이미지 1개 중 1개
    • Use a Phillips #2 screwdriver to remove the three 5.65 mm screws on the bottom panel of the case in a counter-clockwise fashion.
  3. Dell Photo Printer 540 LCD Panel Replacement: 3 단계, 이미지 1개 중 1개
    • Rotate the device so that it is upright again. Under the LCD Panel there is a 9.62 mm screw, unscrew using a Phillips #2 screwdriver.
  4. Dell Photo Printer 540 LCD Panel Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the back panel of the case by pulling directly back.
    • Some carefully applied force may be required to remove this part.
  5. Dell Photo Printer 540 LCD Panel Replacement: 5 단계, 이미지 1개 중 1개
    • Rotate the photo printer so that the bottom panel faces up once again. Now lift off the bottom panel of the case to access all internal components.
  6. Dell Photo Printer 540 LCD Panel Replacement: 6 단계, 이미지 2개 중 1개 Dell Photo Printer 540 LCD Panel Replacement: 6 단계, 이미지 2개 중 2개
    • Finally remove the side panel with the ink-cartridge door by holding the right side and pulling backwards with the left side.
    • Caution! The side panel is held in by tabs; don't break these.
  7. Dell Photo Printer 540 LCD Panel Replacement, Cooling Fan: 7 단계, 이미지 1개 중 1개
    • Carefully remove the inner components of the device by lifting the inner components up and out of the casing.
  8. Dell Photo Printer 540 LCD Panel Replacement: 8 단계, 이미지 1개 중 1개
    • Locate the red and black cable that is connecting the fan to the top of the logic board.
  9. Dell Photo Printer 540 LCD Panel Replacement: 9 단계, 이미지 1개 중 1개
    • Carefully, remove the red and black cable from the logic board by pulling gently in order to isolate the cooling fan from the device.
  10. Dell Photo Printer 540 LCD Panel Replacement, LCD Panel: 10 단계, 이미지 1개 중 1개
    • Locate the data ribbon that connects the LCD panel to the mother board.
    • Carefully unclip the ribbon from the mother board.
    • Separate top cover from bottom base and flip upright so that the LCD panel is facing up for the next step
  11. Dell Photo Printer 540 LCD Panel Replacement: 11 단계, 이미지 2개 중 1개 Dell Photo Printer 540 LCD Panel Replacement: 11 단계, 이미지 2개 중 2개
    • Slide the LCD panel out and away from the printer case.
    • Hold bottom of LCD panel and lift the screen 70 degrees. Set the screen face down for the next step
  12. Dell Photo Printer 540 LCD Panel Replacement: 12 단계, 이미지 1개 중 1개
    • Use a Phillips 00 screwdriver to remove the four 5.4 mm screws behind where the LCD screen is.
  13. Dell Photo Printer 540 LCD Panel Replacement: 13 단계, 이미지 1개 중 1개
    • You can now separate the individual pieces from each other, allowing the screen to be accessible to replace.
결론
작성자
3다른 기여자 명과 함께
Ashley Lopez
회원 가입일: 04/04/12
1 평판
안내서 1개를 작성함
Cal Poly, Team 14-7, Forte Spring 2012 Cal Poly, Team 14-7, Forte Spring 2012 회원
CPSU-FORTE-S12S14G7
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 17
전체 시간: 620
