주요 콘텐츠로 건너뛰기
Dell Precision 5510 Hard Drive Replacement
필요한 것
  1. Dell Precision 5510 Hard Drive Replacement, Base Cover: 1 단계, 이미지 1/1
    • Open the system badge flap over to reveal the screws underneath (marked 1 on the image).
    • Remove the 12 screws that secure the base cover to the computer.
  2. Dell Precision 5510 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Pry the edges base cover and lift it to remove it from computer.
  3. Dell Precision 5510 Hard Drive Replacement, Battery: 3 단계, 이미지 1/2 Dell Precision 5510 Hard Drive Replacement, Battery: 3 단계, 이미지 2/2
    • Unplug the connection that links the battery to the computer.
  4. Dell Precision 5510 Hard Drive Replacement: 4 단계, 이미지 1/2 Dell Precision 5510 Hard Drive Replacement: 4 단계, 이미지 2/2
    • Remove the four 4.0 mm JIS #0 screws surrounding the battery.
  5. Dell Precision 5510 Hard Drive Replacement: 5 단계, 이미지 1/2 Dell Precision 5510 Hard Drive Replacement: 5 단계, 이미지 2/2
    • Carefully remove the battery from the computer.
  6. Dell Precision 5510 Hard Drive Replacement, Hard Drive: 6 단계, 이미지 1/2 Dell Precision 5510 Hard Drive Replacement, Hard Drive: 6 단계, 이미지 2/2
    • Remove the four 4.0 mm screws with a Phillips 1 screwdriver, and remove the hard drive bracket.
  7. Dell Precision 5510 Hard Drive Replacement: 7 단계, 이미지 1/1
    • Unplug the hard drive, and remove it. (We do not have a hard drive to be shown, but see image for where the hard drive would be unplugged from.)
결론
Atlanta Phelps
회원 가입일: 08/28/18
400 평판
안내서 3개 작성하였습니다
IUPUI, Team S1-G5, Arle Fall 2018 IUPUI, Team S1-G5, Arle Fall 2018 회원
IUPUI-ARLE-F18S1G5
3 회원들
안내서 6개 작성하였습니다
0 Comments
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 14
30일 전: 99
전체 시간: 2,782
