주요 콘텐츠로 건너뛰기
Dell Precision 5510 Keyboard Replacement
필요한 것
  1. Dell Precision 5510 Keyboard Replacement, Base Cover: 1 단계, 이미지 1/1
    • Open the system badge flap over to reveal the screws underneath (marked 1 on the image).
    • Remove the 12 screws that secure the base cover to the computer.
  2. Dell Precision 5510 Keyboard Replacement: 2 단계, 이미지 1/1
    • Pry the edges base cover and lift it to remove it from computer.
  3. Dell Precision 5510 Keyboard Replacement, Fans: 3 단계, 이미지 1/2 Dell Precision 5510 Keyboard Replacement, Fans: 3 단계, 이미지 2/2
    • There are two screws on each fan circled in the images shown. Use a Phillips #0 screwdriver to remove all four screws.
    • Each fan has one 3.7mm screw and one 4.65mm screw.
  4. Dell Precision 5510 Keyboard Replacement: 4 단계, 이미지 1/2 Dell Precision 5510 Keyboard Replacement: 4 단계, 이미지 2/2
    • Each of the fans are plugged into the motherboard. Use tweezers to pull the plug out.
    • Do not grab by the wires, grab by the white rectangular region.
  5. Dell Precision 5510 Keyboard Replacement: 5 단계, 이미지 1/2 Dell Precision 5510 Keyboard Replacement: 5 단계, 이미지 2/2
    • Carefully extract the fan from its housing bed. It should remove easily if all parts have been disconnected.
  6. Dell Precision 5510 Keyboard Replacement, Battery: 6 단계, 이미지 1/2 Dell Precision 5510 Keyboard Replacement, Battery: 6 단계, 이미지 2/2
    • Unplug the connection that links the battery to the computer.
  7. Dell Precision 5510 Keyboard Replacement: 7 단계, 이미지 1/2 Dell Precision 5510 Keyboard Replacement: 7 단계, 이미지 2/2
    • Remove the four 4.0 mm JIS #0 screws surrounding the battery.
  8. Dell Precision 5510 Keyboard Replacement: 8 단계, 이미지 1/2 Dell Precision 5510 Keyboard Replacement: 8 단계, 이미지 2/2
    • Carefully remove the battery from the computer.
  9. Dell Precision 5510 Keyboard Replacement, Keyboard: 9 단계, 이미지 1/1
    • Remove 6 screws to take off the heat sink.
  10. Dell Precision 5510 Keyboard Replacement: 10 단계, 이미지 1/1
    • Remove all standalone motherboard screws.
    • 8 screws with lengths of either 3.7mm or 4.65mm
  11. Dell Precision 5510 Keyboard Replacement: 11 단계, 이미지 1/1
    • Remove the motherboard.
  12. Dell Precision 5510 Keyboard Replacement: 12 단계, 이미지 1/1
    • Remove nine screws from the back of the keyboard.
    • Screws are 1.9mm in length
  13. Dell Precision 5510 Keyboard Replacement: 13 단계, 이미지 1/1
    • Pull keyboard out and replace.
결론
Colin Hunter
회원 가입일: 03/31/22
121 평판
안내서 1개 작성함
IUPUI, Team 2-1, Harley Spring 2022 IUPUI, Team 2-1, Harley Spring 2022 회원
IUPUI-HARLEY-S22S2G1
4 회원들
안내서 4개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 21
30일 전: 95
전체 시간: 599
