주요 콘텐츠로 건너뛰기
Dell Precision 5510 RAM Replacement
필요한 것
  1. Dell Precision 5510 RAM Replacement, Base Cover: 1 단계, 이미지 1/1
    • Open the system badge flap over to reveal the screws underneath (marked 1 on the image).
    • Remove the 12 screws that secure the base cover to the computer.
  2. Dell Precision 5510 RAM Replacement: 2 단계, 이미지 1/1
    • Pry the edges base cover and lift it to remove it from computer.
  3. Dell Precision 5510 RAM Replacement, RAM: 3 단계, 이미지 1/2 Dell Precision 5510 RAM Replacement, RAM: 3 단계, 이미지 2/2
    • Chose which RAM board you will be replacing on the motherboard.
    • There are two next to each other. One is outlined here.
  4. Dell Precision 5510 RAM Replacement: 4 단계, 이미지 1/1
    • Place fingers on black plastic tabs.
    • Bend the tabs slightly away from the RAM board until the RAM board springs upward.
  5. Dell Precision 5510 RAM Replacement: 5 단계, 이미지 1/1
    • Once the RAM board springs up to an elevated angle as pictured here, gently grab the board.
    • Pull the board (in the direction shown) out of its slot where it is still inserted .
  6. Dell Precision 5510 RAM Replacement: 6 단계, 이미지 1/1
    • If replacing both RAM boards, follow the same process for removal of the other RAM board.
    • The other board is directly to the right of the prior pictured one, and identical. Both are outlined in this picture.
결론
Cooper Zuranski
회원 가입일: 03/31/22
109 평판
안내서 1개 작성함
IUPUI, Team 2-1, Harley Spring 2022 IUPUI, Team 2-1, Harley Spring 2022 회원
IUPUI-HARLEY-S22S2G1
4 회원들
안내서 4개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 133
