주요 콘텐츠로 건너뛰기
Dell Precision 5510 Screen Replacement
필요한 것
  1. Dell Precision 5510 Screen Replacement, Base Cover: 1 단계, 이미지 1/1
    • Open the system badge flap over to reveal the screws underneath (marked 1 on the image).
    • Remove the 12 screws that secure the base cover to the computer.
  2. Dell Precision 5510 Screen Replacement: 2 단계, 이미지 1/1
    • Pry the edges base cover and lift it to remove it from computer.
  3. Dell Precision 5510 Screen Replacement, Battery: 3 단계, 이미지 1/2 Dell Precision 5510 Screen Replacement, Battery: 3 단계, 이미지 2/2
    • Unplug the connection that links the battery to the computer.
  4. Dell Precision 5510 Screen Replacement: 4 단계, 이미지 1/2 Dell Precision 5510 Screen Replacement: 4 단계, 이미지 2/2
    • Remove the four 4.0 mm JIS #0 screws surrounding the battery.
  5. Dell Precision 5510 Screen Replacement: 5 단계, 이미지 1/2 Dell Precision 5510 Screen Replacement: 5 단계, 이미지 2/2
    • Carefully remove the battery from the computer.
  6. Dell Precision 5510 Screen Replacement, Screen: 6 단계, 이미지 1/2 Dell Precision 5510 Screen Replacement, Screen: 6 단계, 이미지 2/2
    • Remove the six 4.0 mm Phillips #1 screws.
  7. Dell Precision 5510 Screen Replacement: 7 단계, 이미지 1/2 Dell Precision 5510 Screen Replacement: 7 단계, 이미지 2/2
    • Unscrew the one 4.0 mm Phillips #1 screw from the WiFi chip, then remove it.
  8. Dell Precision 5510 Screen Replacement: 8 단계, 이미지 1/2 Dell Precision 5510 Screen Replacement: 8 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Disconnect the black wire. Use tweezers to help.
  9. Dell Precision 5510 Screen Replacement: 9 단계, 이미지 1/2 Dell Precision 5510 Screen Replacement: 9 단계, 이미지 2/2
    • Disconnect the multi wire. Use tweezers to help.
  10. Dell Precision 5510 Screen Replacement: 10 단계, 이미지 1/2 Dell Precision 5510 Screen Replacement: 10 단계, 이미지 2/2
    • Remove the 1.0 mm Phillips #1 screw.
  11. Dell Precision 5510 Screen Replacement: 11 단계, 이미지 1/2 Dell Precision 5510 Screen Replacement: 11 단계, 이미지 2/2
    • Flip the laptop over, so it is sitting in the normal upright position. Hold onto the screen, and pull the keyboard up and away from the screen.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Atlanta Phelps
회원 가입일: 08/28/18
400 평판
안내서 3개 작성하였습니다
IUPUI, Team S1-G5, Arle Fall 2018 IUPUI, Team S1-G5, Arle Fall 2018 회원
IUPUI-ARLE-F18S1G5
3 회원들
안내서 6개 작성하였습니다
댓글 한 개
Can I just change the LCD? Or is changing the entire display assembly the only option?
John Gaines - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 30
전체 시간: 4,010
