주요 콘텐츠로 건너뛰기
Dell Precision 5540 Fans Replacement
필요한 것
    • Ensure that your work surface is flat and clean to prevent the computer cover from being scratched.
    • Turn off your computer.
    • Disconnect your computer from all the cables.
  1. Dell Precision 5540 Fans Replacement, Remove the base cover screws: 2 단계, 이미지 1/2 Dell Precision 5540 Fans Replacement, Remove the base cover screws: 2 단계, 이미지 2/2
    • Close the display lid and turn the computer over.
    • Remove the M2x3 T5 screws that secure the base cover to the computer.
    • Turn the system badge flap over and then remove the M2x8.5 screws that secure the base cover to the computer.
  2. Dell Precision 5540 Fans Replacement, Remove the base cover: 3 단계, 이미지 1/2 Dell Precision 5540 Fans Replacement, Remove the base cover: 3 단계, 이미지 2/2
    • Pry the edges of the base cover and lift it to remove it from the computer. Consider using a spudger.
    • Two case latches are approximately here.
  3. Dell Precision 5540 Fans Replacement, Remove battery plug: 4 단계, 이미지 1/1
    • Here.
    • There is a very small amount of space, so I didn't unplugged it fully, just removed from the socket. And made sure that there is no contact.
  4. Dell Precision 5540 Fans Replacement, Remove CPU fan: 5 단계, 이미지 1/1
    • Unplug the fan cord.
    • Note the dot on the fan power socket which mark the upper side.
    • Unscrew M2 screws.
  5. Dell Precision 5540 Fans Replacement, Remove GPU fan: 6 단계, 이미지 1/1
    • Unscrew M2 screws
결론
Nick Panin
회원 가입일: 05/28/23
133 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 22
전체 시간: 373
