주요 콘텐츠로 건너뛰기
Dell Precision 7510 Memory Module Replacement
필요한 것
  1. Dell Precision 7510 Memory Module Replacement, Removing the Battery Cover: 1 단계, 이미지 1개 중 1개
    • Slide the release latch to unlock the battery cover.
    • Slide and lift the battery cover to remove it from the computer.
  2. Dell Precision 7510 Memory Module Replacement, Removing the Battery Cover: 2 단계, 이미지 1개 중 1개
  3. Dell Precision 7510 Memory Module Replacement, Removing the Hard Drive: 3 단계, 이미지 1개 중 1개
    • Remove the screws that secure the hard drive to the computer.
    • Lift the hard-drive latch to the unlock position.
    • Slide and lift the hard drive from the computer.
  4. Dell Precision 7510 Memory Module Replacement, Remove the Screws: 4 단계, 이미지 1개 중 1개
    • Remove the screws that secure the hard drive. Lift the hard drive away from the bracket.
  5. Dell Precision 7510 Memory Module Replacement, Removing the Keyboard Cables: 5 단계, 이미지 1개 중 1개
    • Peel the tape to access the cable.
    • Lift the tab and disconnect the keyboard cables from the system board.
  6. Dell Precision 7510 Memory Module Replacement, Removing the Keyboard: 6 단계, 이미지 1개 중 1개
    • Pry the keyboard trim starting from bottom and work along the top edge and remove it away from the computer.
    • Remove the screws that secure the keyboard to the computer.
    • Lift the front side and slide the keyboard to remove it away from the computer.
  7. Dell Precision 7510 Memory Module Replacement, Removing the Memory Module: 7 단계, 이미지 1개 중 1개
    • Remove the screw that secures the memory shield to the computer.
    • Lift and remove the memory shield from the computer.
    • Pry the retention clips away from the memory module until it pops up.
    • Lift the memory module and remove it from the computer.
  8. Dell Precision 7510 Memory Module Replacement, Removing the Memory Module: 8 단계, 이미지 1개 중 1개
    • Pry the retention clips away from the primary memory until it pops up.
    • Lift the primary memory and remove it from the computer.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Johnathan Hammond
회원 가입일: 02/28/18
45,555 평판
안내서 408개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,994개를 작성함
1가이드 댓글
Thanks Johnathan. Step 4 is unnecessary.
Joseph R. Scandora - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 52
전체 시간: 11,495
