주요 콘텐츠로 건너뛰기
Dell Precision 7560 Fan Replacement
필요한 것
  1. Dell Precision 7560 Fan Replacement, Fan: 1 단계, 이미지 1/2 Dell Precision 7560 Fan Replacement, Fan: 1 단계, 이미지 2/2
    • The screws holding the fan in place cannot be fully removed.
    • Loosen the eight captive screws that secure the fan assembly.
    • Each screw is numbered in the order that they should be loosened.
  2. Dell Precision 7560 Fan Replacement: 2 단계, 이미지 1/2 Dell Precision 7560 Fan Replacement: 2 단계, 이미지 2/2
    • Locate connector cable and pull lightly to remove.
  3. Dell Precision 7560 Fan Replacement: 3 단계, 이미지 1/2 Dell Precision 7560 Fan Replacement: 3 단계, 이미지 2/2
    • Gently pull the first fan connector from the head until it is removed.
    • The thin wire is prone to damage. Exercise extra caution during removal.
  4. Dell Precision 7560 Fan Replacement: 4 단계, 이미지 1/2 Dell Precision 7560 Fan Replacement: 4 단계, 이미지 2/2
    • Gently pull the second fan connector from the head until it is removed.
  5. Dell Precision 7560 Fan Replacement: 5 단계, 이미지 1/2 Dell Precision 7560 Fan Replacement: 5 단계, 이미지 2/2
    • Lifting from the bottom, carefully remove the laptop's fans.
결론
Jack Allred
회원 가입일: 02/09/23
336 평판
안내서 2개 작성하였습니다
Utah Tech University, Team 1-1, McMurrin Spring 2023 Utah Tech University, Team 1-1, McMurrin Spring 2023 회원
UTAHTECH-MCMURRIN-S23S1G1
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 14
30일 전: 67
전체 시간: 776
