주요 콘텐츠로 건너뛰기
Dell Precision 7560 Keyboard Replacement
필요한 것
  1. Dell Precision 7560 Keyboard Replacement, Battery: 1 단계, 이미지 1/3 Dell Precision 7560 Keyboard Replacement, Battery: 1 단계, 이미지 2/3 Dell Precision 7560 Keyboard Replacement, Battery: 1 단계, 이미지 3/3
    • The screws holding the back cover in place can not be removed.
    • Use a Phillips #0 screwdriver to loosen the the eight 5 mm captive screws in the bottom cover.
    • Remove the back cover by lifting at the corners.
  2. Dell Precision 7560 Keyboard Replacement: 2 단계, 이미지 1/3 Dell Precision 7560 Keyboard Replacement: 2 단계, 이미지 2/3 Dell Precision 7560 Keyboard Replacement: 2 단계, 이미지 3/3
    • Unscrew and remove the five 2 mm screws that secure the battery.
    • Locate the battery connector.
  3. Dell Precision 7560 Keyboard Replacement: 3 단계, 이미지 1/3 Dell Precision 7560 Keyboard Replacement: 3 단계, 이미지 2/3 Dell Precision 7560 Keyboard Replacement: 3 단계, 이미지 3/3
    • Pull the connector towards you to disconnect it.
    • Use your fingers or a plastic opening tool to pry the battery up and remove it from the laptop.
  4. Dell Precision 7560 Keyboard Replacement, Keyboard: 4 단계, 이미지 1/3 Dell Precision 7560 Keyboard Replacement, Keyboard: 4 단계, 이미지 2/3 Dell Precision 7560 Keyboard Replacement, Keyboard: 4 단계, 이미지 3/3
    • With the back cover and battery removed, locate the ribbon cables connected to the keyboard.
    • Pulling from the tab, carefully remove the connector.
  5. Dell Precision 7560 Keyboard Replacement: 5 단계, 이미지 1/3 Dell Precision 7560 Keyboard Replacement: 5 단계, 이미지 2/3 Dell Precision 7560 Keyboard Replacement: 5 단계, 이미지 3/3
    • Turn the device over and open the screen to expose the keyboard.
    • Using an opener tool, pry along the edges of the keyboard to remove the keyboard's plate cover.
  6. Dell Precision 7560 Keyboard Replacement: 6 단계, 이미지 1/3 Dell Precision 7560 Keyboard Replacement: 6 단계, 이미지 2/3 Dell Precision 7560 Keyboard Replacement: 6 단계, 이미지 3/3
    • With the plate cover removed, use the screwdriver to remove each of the six 2 mm screws.
    • Carefully remove the keyboard from the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jack Allred
회원 가입일: 02/09/23
336 평판
안내서 2개 작성하였습니다
Utah Tech University, Team 1-1, McMurrin Spring 2023 Utah Tech University, Team 1-1, McMurrin Spring 2023 회원
UTAHTECH-MCMURRIN-S23S1G1
3 회원들
안내서 6개 작성하였습니다
댓글 한 개
Guide is close, but not completely correct. Just need a little more attention to detail.
Barry Todd - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 60
전체 시간: 731
