주요 콘텐츠로 건너뛰기
Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement
필요한 것
  1. Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement, NVMe Solid-State Drive (Expansion): 1 단계, 이미지 1/3 Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement, NVMe Solid-State Drive (Expansion): 1 단계, 이미지 2/3 Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement, NVMe Solid-State Drive (Expansion): 1 단계, 이미지 3/3
    • The screws holding the back cover in place can not be removed.
    • Use a Phillips #0 screwdriver to loosen the eight 5 mm captive screws in the bottom cover.
    • Remove the back cover by lifting at the corners.
  2. Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement: 2 단계, 이미지 1/2 Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement: 2 단계, 이미지 2/2
    • Use the Phillips #0 screwdriver to unscrew and remove the two 2 mm screws that secure the expansion NVMe SSD sticks.
  3. Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement: 3 단계, 이미지 1/2 Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement: 3 단계, 이미지 2/2
    • Disconnect the left SSD stick by pulling its exposed end towards you.
    • Repeat the same procedure to the right SSD stick.
결론
Hector
회원 가입일: 02/14/23
249 평판
안내서 2개 작성하였습니다
Utah Tech University, Team 1-1, McMurrin Spring 2023 Utah Tech University, Team 1-1, McMurrin Spring 2023 회원
UTAHTECH-MCMURRIN-S23S1G1
3 회원들
안내서 6개 작성하였습니다
댓글 한 개
This is not for RAM this is for the SSD upgrades.
Kurtis - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 29
전체 시간: 285
