주요 콘텐츠로 건너뛰기
Dell Precision 7560 Screen Replacement
필요한 것
  1. Dell Precision 7560 Screen Replacement, Screen: 1 단계, 이미지 1/3 Dell Precision 7560 Screen Replacement, Screen: 1 단계, 이미지 2/3 Dell Precision 7560 Screen Replacement, Screen: 1 단계, 이미지 3/3
    • Using an opener tool, pry open the bezel, following along the screen's perimeter.
    • Lightly pull from the corners to remove the bezel.
  2. Dell Precision 7560 Screen Replacement: 2 단계, 이미지 1/2 Dell Precision 7560 Screen Replacement: 2 단계, 이미지 2/2
    • Use the Phillips #0 screwdriver to remove:
    • Two 2 mm screws from the top screen brackets.
    • Two 3 mm screws from the bottom screen brackets.
    • Once these screws are removed, you should be able to gently pry the laptop screen free.
    • Be careful not to apply too much pressure, as this could damage the screen or other components inside the laptop.
  3. Dell Precision 7560 Screen Replacement: 3 단계, 이미지 1/3 Dell Precision 7560 Screen Replacement: 3 단계, 이미지 2/3 Dell Precision 7560 Screen Replacement: 3 단계, 이미지 3/3
    • To fully disconnect the screen, gently peel off the white tape that secures the video connector.
    • Remove the blue tape that lies between the white tape and the video connector.
    • Open the video connector's bracket and remove the cable, pulling towards the back of the device.
결론
Laisha
회원 가입일: 02/14/23
202 평판
안내서 2개 작성하였습니다
Utah Tech University, Team 1-1, McMurrin Spring 2023 Utah Tech University, Team 1-1, McMurrin Spring 2023 회원
UTAHTECH-MCMURRIN-S23S1G1
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 61
전체 시간: 634
