주요 콘텐츠로 건너뛰기
Dell Precision 7560 Solid-State Drive (SSD) Replacement
필요한 것
  1. Dell Precision 7560 Solid-State Drive (SSD) Replacement, Battery: 1 단계, 이미지 1/3 Dell Precision 7560 Solid-State Drive (SSD) Replacement, Battery: 1 단계, 이미지 2/3 Dell Precision 7560 Solid-State Drive (SSD) Replacement, Battery: 1 단계, 이미지 3/3
    • The screws holding the back cover in place can not be removed.
    • Use a Phillips #0 screwdriver to loosen the the eight 5 mm captive screws in the bottom cover.
    • Remove the back cover by lifting at the corners.
  2. Dell Precision 7560 Solid-State Drive (SSD) Replacement: 2 단계, 이미지 1/3 Dell Precision 7560 Solid-State Drive (SSD) Replacement: 2 단계, 이미지 2/3 Dell Precision 7560 Solid-State Drive (SSD) Replacement: 2 단계, 이미지 3/3
    • Unscrew and remove the five 2 mm screws that secure the battery.
    • Locate the battery connector.
  3. Dell Precision 7560 Solid-State Drive (SSD) Replacement: 3 단계, 이미지 1/3 Dell Precision 7560 Solid-State Drive (SSD) Replacement: 3 단계, 이미지 2/3 Dell Precision 7560 Solid-State Drive (SSD) Replacement: 3 단계, 이미지 3/3
    • Pull the connector towards you to disconnect it.
    • Use your fingers or a plastic opening tool to pry the battery up and remove it from the laptop.
  4. Dell Precision 7560 Solid-State Drive (SSD) Replacement, Solid-State Drive (SSD): 4 단계, 이미지 1/2 Dell Precision 7560 Solid-State Drive (SSD) Replacement, Solid-State Drive (SSD): 4 단계, 이미지 2/2
    • Unscrew and remove the two 3 mm screws that secure the solid-state drive.
  5. Dell Precision 7560 Solid-State Drive (SSD) Replacement: 5 단계, 이미지 1/2 Dell Precision 7560 Solid-State Drive (SSD) Replacement: 5 단계, 이미지 2/2
    • Remove the top cover of the Solid State Drive by lifting up from the corners.
    • Notice that the Solid State Drive is located underneath the cover.
    • Pull the Solid State Drive gently towards you from its exposed end to disconnect it.
    • With an appropriate replacement part, exchange the old SSD with a new one.
결론
Hector
회원 가입일: 02/14/23
249 평판
안내서 2개 작성하였습니다
Utah Tech University, Team 1-1, McMurrin Spring 2023 Utah Tech University, Team 1-1, McMurrin Spring 2023 회원
UTAHTECH-MCMURRIN-S23S1G1
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 34
전체 시간: 506
