주요 콘텐츠로 건너뛰기
Dell Precision M3800 Fan Replacement
필요한 것
  1. Dell Precision M3800 Fan Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 Dell Precision M3800 Fan Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • Be sure to power off and unplug your device before you begin your repair.
    • Use a T5 Torx screwdriver to unscrew the ten 3mm screws on the laptop back cover.
    • iFixit’s magnetic project mat is great for keeping the screws in one place.
    • Lift up the silver cover from the back panel to reveal two screws.
    • Use a Phillips screwdriver to remove the two screws underneath the silver cover.
  2. Dell Precision M3800 Fan Replacement: 2 단계, 이미지 1개 중 1개
    • Use an opening tool to pry around the edges of the back panel to loosen the panel.
    • Remove the back panel.
  3. Dell Precision M3800 Fan Replacement, Fan: 3 단계, 이미지 2개 중 1개 Dell Precision M3800 Fan Replacement, Fan: 3 단계, 이미지 2개 중 2개
    • Use a Phillips #00 screwdriver to unscrew the two 3.5mm screws that are holding the fans in place.
  4. Dell Precision M3800 Fan Replacement: 4 단계, 이미지 3개 중 1개 Dell Precision M3800 Fan Replacement: 4 단계, 이미지 3개 중 2개 Dell Precision M3800 Fan Replacement: 4 단계, 이미지 3개 중 3개
    • Using a nonmetal prying tool, unplug the cord connecting the fan to the motherboard.
    • If replacing the right fan, this cord is located underneath the fan.
    • If replacing the left fan, this cord is located on the left of the fan.
  5. Dell Precision M3800 Fan Replacement: 5 단계, 이미지 2개 중 1개 Dell Precision M3800 Fan Replacement: 5 단계, 이미지 2개 중 2개
    • Use nonmetal prying tool to lift the bottom of the fan from the laptop body (this will require some force and you will hear an adhesive pulling sound).
    • Repeat the steps for the second fan if needed .
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Brianna Hitchcock
회원 가입일: 09/17/19
885 평판
안내서 7개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 13
지난 7일: 14
지난 30일: 25
전체 시간: 1,441
