주요 콘텐츠로 건너뛰기
Dell Precision M4800 Wi-Fi Card Replacement
필요한 것
  1. Dell Precision M4800 Wi-Fi Card Replacement, Wi-Fi Card: 1 단계, 이미지 1/3 Dell Precision M4800 Wi-Fi Card Replacement, Wi-Fi Card: 1 단계, 이미지 2/3 Dell Precision M4800 Wi-Fi Card Replacement, Wi-Fi Card: 1 단계, 이미지 3/3
    • Ensure that all electrical sources are removed and turned off.
    • Unplug the charger from the laptop and shut it down.
    • Flip the computer, so the bottom is facing upwards.
    • Slide the release latch to release the battery.
    • Lift and remove the battery from the laptop.
  2. Dell Precision M4800 Wi-Fi Card Replacement: 2 단계, 이미지 1/3 Dell Precision M4800 Wi-Fi Card Replacement: 2 단계, 이미지 2/3 Dell Precision M4800 Wi-Fi Card Replacement: 2 단계, 이미지 3/3
    • Using a Phillips #1 screwdriver, remove the two 5 mm screws fastening the backplate.
    • Slide the base cover towards the rear of the laptop.
    • Lift the base cover and remove it from the laptop.
  3. Dell Precision M4800 Wi-Fi Card Replacement: 3 단계, 이미지 1/3 Dell Precision M4800 Wi-Fi Card Replacement: 3 단계, 이미지 2/3 Dell Precision M4800 Wi-Fi Card Replacement: 3 단계, 이미지 3/3
    • Disconnect the black and white antenna cables by carefully pulling them upwards away from the card, being cautious to not bend the connector.
    • For the antenna pins a simple and slight nudge is usually enough, but remember that these pins are somewhat delicate.
    • Remove the screw.
  4. Dell Precision M4800 Wi-Fi Card Replacement: 4 단계, 이미지 1/2 Dell Precision M4800 Wi-Fi Card Replacement: 4 단계, 이미지 2/2
    • Remove the Wi-Fi card.
  5. Dell Precision M4800 Wi-Fi Card Replacement: 5 단계, 이미지 1/2 Dell Precision M4800 Wi-Fi Card Replacement: 5 단계, 이미지 2/2
    • Slide the replacement Wi-Fi card into the slot.
    • Tighten the screw securing the Wi-Fi card.
  6. Dell Precision M4800 Wi-Fi Card Replacement: 6 단계, 이미지 1/2 Dell Precision M4800 Wi-Fi Card Replacement: 6 단계, 이미지 2/2
    • Connect both antenna cables back to the same places according to the color code on the Wi-Fi card.
  7. Dell Precision M4800 Wi-Fi Card Replacement: 7 단계, 이미지 1/3 Dell Precision M4800 Wi-Fi Card Replacement: 7 단계, 이미지 2/3 Dell Precision M4800 Wi-Fi Card Replacement: 7 단계, 이미지 3/3
    • Slide the base cover towards the front of the laptop.
    • Slide the battery back into its place.
    • Make sure to put a little pressure on it if the battery is not fully in place. The battery release latch will automatically click back to the locked position.
결론
Naveen
회원 가입일: 09/19/23
195 평판
안내서 1개 작성함
York University, Team B-19, Woodhouse Fall 2023 York University, Team B-19, Woodhouse Fall 2023 회원
YORK-WOODHOUSE-F23SBG19
2 회원들
안내서 1개 작성하였습니다
댓글 한 개
Great guide, well-written and concise. Thank you for sharing your knowledge and expertise. Best regards
Loren Martin - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 15
30일 전: 52
전체 시간: 419
