주요 콘텐츠로 건너뛰기
Dell Precision M6600 Hard Drive Replacement
필요한 것
  1. Dell Precision M6600 Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Slide the lock key to unlock the battery. Then you can lift the battery from its holder.
  2. Dell Precision M6600 Hard Drive Replacement, Remove Bottom Cover: 2 단계, 이미지 1/2 Dell Precision M6600 Hard Drive Replacement, Remove Bottom Cover: 2 단계, 이미지 2/2
    • Using Phillips screwdriver, remove 2 screws holding case.
    • Slide case towards back of laptop then lift off to remove.
  3. Dell Precision M6600 Hard Drive Replacement, Remove the Hard Drive: 3 단계, 이미지 1/2 Dell Precision M6600 Hard Drive Replacement, Remove the Hard Drive: 3 단계, 이미지 2/2
    • Using a Phillips Screwdriver, remove the 4 screws that hold the hard drive in place.
    • Using a Phillips #00 take out the 1.5mm screw then slide to unlock the SSD holder.
  4. Dell Precision M6600 Hard Drive Replacement: 4 단계, 이미지 1/1
    • When the lock was slid, a medal holder popped out and that is where the SSD is hidden.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Kaley lindsay
회원 가입일: 03/23/18
582 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S8-G3, Valliere Spring 2018 UMass Dartmouth, Team S8-G3, Valliere Spring 2018 회원
UMASSD-VALLIERE-S18S8G3
2 회원들
안내서 4개 작성하였습니다
댓글 한 개
How do you remove the bottom? Instructions only show removal of battery then next step shows full access to bottom of laptop? My slide switch doesn’t release the door, any thoughts?
Jason Zuehlke - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 35
전체 시간: 3,588
