주요 콘텐츠로 건너뛰기
Dell Precision M6800 Keyboard Replacement
필요한 것
  1. Dell Precision M6800 Keyboard Replacement, Dell Precision M6800: 1 단계, 이미지 1/1
    • Replacing Dell Precision M6800's keyboard
  2. Dell Precision M6800 Keyboard Replacement: 2 단계, 이미지 1/2 Dell Precision M6800 Keyboard Replacement: 2 단계, 이미지 2/2
    • Before any repair, you should remove battery
  3. Dell Precision M6800 Keyboard Replacement: 3 단계, 이미지 1/1
    • Pry and remove the frame around keyboard (it's a bit lighter than rest of casing).
  4. Dell Precision M6800 Keyboard Replacement: 4 단계, 이미지 1/1
    • Unscrew 4 fastening screws which are at bottom of keyboard
  5. Dell Precision M6800 Keyboard Replacement: 5 단계, 이미지 1/2 Dell Precision M6800 Keyboard Replacement: 5 단계, 이미지 2/2
    • Pry out four hooks which are on the sides of keyboard (two per one site)
    • Be carefull to not break of hooks - use constant force and do it slowly
  6. Dell Precision M6800 Keyboard Replacement: 6 단계, 이미지 1/2 Dell Precision M6800 Keyboard Replacement: 6 단계, 이미지 2/2
    • Pick up a little keyboard and eject it. Than pick up harder but DO NOT take it out
    • DO NOT take keyboard out, it is connect to the motherboard and you must unhook it in next step
  7. Dell Precision M6800 Keyboard Replacement: 7 단계, 이미지 1/2 Dell Precision M6800 Keyboard Replacement: 7 단계, 이미지 2/2
    • Pry up the white part of connector (constant for both sides) and eject connecting flex
결론
다른 4명이 해당 안내서를 완성하였습니다.
Szymon Milewski
회원 가입일: 12/28/20
741 평판
안내서 3개 작성하였습니다
댓글 2개
Great job, thank you
kali1902 - 답글
Broke off the stupid white clip holding the connector in place go to h ell
Stan B - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 35
전체 시간: 1,263
