주요 콘텐츠로 건너뛰기
Dell Precision T5600 RAM Replacement
  1. Dell Precision T5600 RAM Replacement, RAM: 1 단계, 이미지 1/1
    • Unplug the computer from the power supply before any maintenance or disassembly.
    • Lay the case on its side with the handle side pointing up. Remove the side panel of the computer case by pulling on the handle, as shown in this step.
    • Be sure to use an anti-static mat to ensure important components are not damaged by static electricity.
  2. Dell Precision T5600 RAM Replacement: 2 단계, 이미지 1/1
    • Unlock the RAM by pressing down on the tabs on each end of the RAM socket.
    • Once both tabs have been pushed down, gently pull out the existing RAM stick from the motherboard.
  3. Dell Precision T5600 RAM Replacement: 3 단계, 이미지 1/2 Dell Precision T5600 RAM Replacement: 3 단계, 이미지 2/2
    • Line up the RAM with the groove on the connector line.
    • Do not touch the gold connectors.
  4. Dell Precision T5600 RAM Replacement: 4 단계, 이미지 1/2 Dell Precision T5600 RAM Replacement: 4 단계, 이미지 2/2
    • Gently insert the RAM into the socket until you feel the tabs from Step 3 click into place.
    • Ensure that both ends of the RAM are secured by their tabs.
  5. Dell Precision T5600 RAM Replacement: 5 단계, 이미지 1/1
    • Reattach the side panel from Step 2. Plug your computer back up to the power supply and power on your computer.
    • Once powered on, to verify the installation:
    • Right-click on 'This PC'
    • Left-click on 'Properties'
결론
Fahad Khan
회원 가입일: 07/05/21
133 평판
안내서 1개 작성함
York University, Team S70-G120, Allen Summer 2021 York University, Team S70-G120, Allen Summer 2021 회원
YORK-ALLEN-SU21S70G120
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 14
전체 시간: 604
