주요 콘텐츠로 건너뛰기
Dell Streak 10 Pro Rear Camera Replacement
필요한 것
  1. Dell Streak 10 Pro Rear Camera Replacement, Battery: 1 단계, 이미지 1/3 Dell Streak 10 Pro Rear Camera Replacement, Battery: 1 단계, 이미지 2/3 Dell Streak 10 Pro Rear Camera Replacement, Battery: 1 단계, 이미지 3/3
    • Place the device flat on its screen.
    • Using the plastic opening tools, pry open the top segment of the tablet where the camera is located.
    • Take the segment off and place it to the side.
  2. Dell Streak 10 Pro Rear Camera Replacement: 2 단계, 이미지 1/2 Dell Streak 10 Pro Rear Camera Replacement: 2 단계, 이미지 2/2
    • Remove four 4mm Phillips #0 screws.
  3. Dell Streak 10 Pro Rear Camera Replacement: 3 단계, 이미지 1/2 Dell Streak 10 Pro Rear Camera Replacement: 3 단계, 이미지 2/2
    • Using the plastic opening tool, lift off the entire back screen of the tablet.
  4. Dell Streak 10 Pro Rear Camera Replacement: 4 단계, 이미지 1/3 Dell Streak 10 Pro Rear Camera Replacement: 4 단계, 이미지 2/3 Dell Streak 10 Pro Rear Camera Replacement: 4 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Disconnect the no-fuss ribbon cable connector.
    • The best way is to safely pull the white connector straight out of the socket. Using the tweezers, pull out the white connector that contains the red, green, blue, and black cords connected to it.
    • Remove the battery by gently lifting it out of the device.
  5. Dell Streak 10 Pro Rear Camera Replacement, Rear Camera: 5 단계, 이미지 1/2 Dell Streak 10 Pro Rear Camera Replacement, Rear Camera: 5 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Disconnect the no-fuss ribbon cable connector. Using tweezers, carefully pull the connector straight out of the socket.
    • The white connector is attached to a black wire.
  6. Dell Streak 10 Pro Rear Camera Replacement: 6 단계, 이미지 1/2 Dell Streak 10 Pro Rear Camera Replacement: 6 단계, 이미지 2/2
    • Disconnect the delicate ribbon cable from the Zero Insertion Force (ZIF) Connector.
    • To disconnect the cable, use the tip of a spudger or your fingernail to flip up the small black locking flap. Then, you can safely pull the cable out.
  7. Dell Streak 10 Pro Rear Camera Replacement: 7 단계, 이미지 1/2 Dell Streak 10 Pro Rear Camera Replacement: 7 단계, 이미지 2/2
    • Using the tweezer, carefully wiggle off the camera attached to the base.
    • This may take a few minutes. Be gentle while applying pressure.
    • After it wiggles free, lift the camera away from the base of the tablet.
결론
Kayji Arai
회원 가입일: 02/05/19
211 평판
안내서 2개 작성하였습니다
UC Davis, Team S20-G7, Lore Winter 2019 UC Davis, Team S20-G7, Lore Winter 2019 회원
UCD-LORE-W19S20G7
2 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 4
전체 시간: 90
