소개
Use this guide to replace the battery in the Dell Streak 7. This guide will show the steps required to replace the battery in the tablet.
필요한 것
Insert the spudger under the capacitive button panel, and slide the spudger all the way around.
Using the spudger, disconnect the ribbon cable by lifting up on the connector.
Use the spudger to lift up and detach the cable connecting the battery to the motherboard.
다른 3명이 해당 안내서를 완성하였습니다.
