주요 콘텐츠로 건너뛰기
Dell Streak Display Replacement
필요한 것
  1. Dell Streak Display Replacement, Display: 1 단계, 이미지 1/3 Dell Streak Display Replacement, Display: 1 단계, 이미지 2/3 Dell Streak Display Replacement, Display: 1 단계, 이미지 3/3
    • Loosen any clamps that hold the LCD screen in place. Some of the clamps may not be loosened yet, leave them attached for now.
  2. Dell Streak Display Replacement: 2 단계, 이미지 1/2 Dell Streak Display Replacement: 2 단계, 이미지 2/2
    • The gorilla glass is pinned to the case. You must take a slotted screwdriver to go around the case and separate the gorilla glass from the case.
    • In some instances the gorilla glass may seperate from the LCD fairly easily, or it maybe hard to release.
    • (Don't feel sorry for the broken display, it doesn't deserve to be treated gently..)
  3. Dell Streak Display Replacement: 3 단계, 이미지 1/3 Dell Streak Display Replacement: 3 단계, 이미지 2/3 Dell Streak Display Replacement: 3 단계, 이미지 3/3
    • Lift the new display out of the case. You should fold the LCD ribbon cable to do this.
  4. Dell Streak Display Replacement: 4 단계, 이미지 1/2 Dell Streak Display Replacement: 4 단계, 이미지 2/2
    • Really good, the display is out of the case.
    • Remember the lifted display is no longer for use. For example, i brought the touchscreen ribbon cable even though i was careful.
  5. Dell Streak Display Replacement: 5 단계, 이미지 1/1
    • Insert the brand new display! Remind, you must do step 3 to 2 in reversed direction. The hardest part for me was to fold the LCD ribbon cable of the new display, but don't be shy, do it!
    • Reassemble your Phone
  6. Dell Streak Display Replacement: 6 단계, 이미지 1/2 Dell Streak Display Replacement: 6 단계, 이미지 2/2
    • Perfect, it's done!
    • Don't be alarmed if the screen is black when you re-start your phone for the first time and the buttons are only glowing. This may happen, but removing and reinserting the battery should restart it and cause it to function properly!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Fix my problems myself
회원 가입일: 12/10/10
71 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 23,267
