이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Gather materials and tools
Flip laptop over
Remove battery and power cord before doing anything
Where the battery was, take out the two screws with the letter "K" next to them
Save the screws somewhere safe, and flip the laptop rightside up
Open the laptop
Take the flathead screwdriver, and put it under the bezel that goes around the keyboard
If you're simply fixing the existing keyboard, be careful not to pry a key off. They are close to impossible to get back on
Pry the bezel out of the frame. It might take some effort, but this is the correct method
Once one part has snapped out of the frame, continue to carefully remove the rest of the bezel
Once the bezel is removed, put the screwdriver under the media control bar
Continue to apply pressure, prying it out of place; it should snap out easy
Do not rip it out without precaution. It's attached with a delicate ribbon cable, and if damaged, you'll be replacing more than the keyboard
Once snapped out of it's place, flip it over gently onto the keyboard
Unscrew the two screws at the top of the keyboard using the Phillips screwdriver
Set the screws aside along with the other ones. They are the same size, no need to worry about getting them mixed up
Now that the screws are out, lift the top of the keyboard
You will notice some resistance due to clips on the sides. Lift the side of the keyboard gently, taking the board out of the clip without breaking it
Once both sides are out of the clips, slide the keyboard forward a bit
Flip the keyboard over, minding the ribbon cable, over onto the palmrest
Now that they physical keyboard is removed, we can focus on the ribbon cable
Caution, this step can make or break the connection point, so be gentle
Gently flip the black hatch part of the connection point upwards
Remove the ribbon cable from the connection point
When re-installing the cable, be sure that it is inserted all the way, and that the hatch is closed. If not, it may malfunction, or not work at all, and you will have to do this all over again
다른 9명이 해당 안내서를 완성하였습니다.
