필요한 것
Slide the battery release latch until it clicks into place.
Slide the battery out of the battery bay.
Loosen the seven captive screws on the base cover and lift the cover off the computer at an angle as shown in the figure.
Remove the four screws securing the hard drive assembly to the computer.
Pull the hard drive cable pull-tab to disconnect the cable from the system board connector.
Pull on the hard drive pull-tab to lift the hard drive assembly from the bay.
다른 한 분이 해당 안내서를 완성하였습니다.
