주요 콘텐츠로 건너뛰기
Dell Studio 1537 Hard Drive Replacement
필요한 것
  1. Dell Studio 1537 Hard Drive Replacement, Battery: 1 단계, 이미지 1/2 Dell Studio 1537 Hard Drive Replacement, Battery: 1 단계, 이미지 2/2
    • Ensure the laptop is turned off and unplugged before attempting to remove any piece.
    • Place the laptop lid down so the underside is visible.
    • Pull battery release switch and gently pull the battery directly away from the switch.
  2. Dell Studio 1537 Hard Drive Replacement, Back Cover: 2 단계, 이미지 1/1
    • Identify the back cover of the laptop.
  3. Dell Studio 1537 Hard Drive Replacement: 3 단계, 이미지 1/1
    • Unscrew and remove all of the 6.0mm screws with a Phillips #1 screwdriver.
  4. Dell Studio 1537 Hard Drive Replacement: 4 단계, 이미지 1/1
    • Lift the back cover off of the laptop.
  5. Dell Studio 1537 Hard Drive Replacement, Hard Drive: 5 단계, 이미지 1/2 Dell Studio 1537 Hard Drive Replacement, Hard Drive: 5 단계, 이미지 2/2
    • Unscrew all of the 6.0 mm screws with a Phillips #1 screwdriver holding the hard drive cage on the computer.
  6. Dell Studio 1537 Hard Drive Replacement: 6 단계, 이미지 1/2 Dell Studio 1537 Hard Drive Replacement: 6 단계, 이미지 2/2
    • Lift the hard drive cage out of the laptop.
  7. Dell Studio 1537 Hard Drive Replacement: 7 단계, 이미지 1/3 Dell Studio 1537 Hard Drive Replacement: 7 단계, 이미지 2/3 Dell Studio 1537 Hard Drive Replacement: 7 단계, 이미지 3/3
    • Pull tab to unplug the drive from the computer
    • Pull the hard drive out of the hard drive tray.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Zach Dylag
회원 가입일: 03/24/15
575 평판
안내서 4개 작성하였습니다
Baylor, Team 6-2, Shaver Spring 2015 Baylor, Team 6-2, Shaver Spring 2015 회원
BU-SHAVER-S15S6G2
3 회원들
안내서 4개 작성하였습니다
댓글 한 개
Straightforward process with step by step guide. Thank you Zach.
Katharine Church - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 13
전체 시간: 2,511
