주요 콘텐츠로 건너뛰기
Dell Studio 1555 Back Panel Removal
필요한 것
  1. Dell Studio 1555 Back Panel Removal, Battery: 1 단계, 이미지 1/1
    • Turn off and unplug the laptop.
    • Failure to properly turn off device before handling the battery could result in electrical shock.
    • Flip the laptop so the underside is facing up with the battery closest to you.
  2. Dell Studio 1555 Back Panel Removal: 2 단계, 이미지 1/3 Dell Studio 1555 Back Panel Removal: 2 단계, 이미지 2/3 Dell Studio 1555 Back Panel Removal: 2 단계, 이미지 3/3
    • Slide the locking switch to the left to release the battery.
  3. Dell Studio 1555 Back Panel Removal: 3 단계, 이미지 1/1
    • Gently pull the battery away from the device.
  4. Dell Studio 1555 Back Panel Removal, Back Panel: 4 단계, 이미지 1/3 Dell Studio 1555 Back Panel Removal, Back Panel: 4 단계, 이미지 2/3 Dell Studio 1555 Back Panel Removal, Back Panel: 4 단계, 이미지 3/3
    • Loosen the three 5mm screws from the back panel using the # 1 Philips screwdriver.
    • The three 5mm screws will stay in place on the back panel.
  5. Dell Studio 1555 Back Panel Removal: 5 단계, 이미지 1/1
    • Carefully remove the separated back panel.
    • If the back panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that all the screws are unscrewed all the way before attempting again.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Josh Boone
회원 가입일: 10/10/16
586 평판
안내서 4개 작성하였습니다
Sam Houston State, Team 12-3, Blackburne Fall 2016 Sam Houston State, Team 12-3, Blackburne Fall 2016 회원
SHSU-BLACKBURNE-F16S12G3
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 9
전체 시간: 584
