소개
To be able to access certain components like the hard drive or motherboard of the Dell Studio 1555, the back panel will need to be removed. A Phillips 1 screwdriver is required for this guide.
필요한 것
Turn off and unplug the laptop.
Flip the laptop so the underside is facing up with the battery closest to you.
Loosen the three 5mm screws from the back panel using the # 1 Philips screwdriver.
다른 2명이 해당 안내서를 완성하였습니다.
