주요 콘텐츠로 건너뛰기
Dell Studio 1555 Display Replacement
필요한 것
  1. Dell Studio 1555 Display Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn off and unplug the laptop.
    • Failure to properly turn off device before handling the battery could result in electrical shock.
    • Flip the laptop so the underside is facing up with the battery closest to you.
  2. Dell Studio 1555 Display Replacement: 2 단계, 이미지 3개 중 1개 Dell Studio 1555 Display Replacement: 2 단계, 이미지 3개 중 2개 Dell Studio 1555 Display Replacement: 2 단계, 이미지 3개 중 3개
    • Slide the locking switch to the left to release the battery.
  3. Dell Studio 1555 Display Replacement: 3 단계, 이미지 1개 중 1개
    • Gently pull the battery away from the device.
  4. Dell Studio 1555 Display Replacement, Display: 4 단계, 이미지 2개 중 1개 Dell Studio 1555 Display Replacement, Display: 4 단계, 이미지 2개 중 2개
    • Insert a plastic opening tool between the bezel and the display cover.
    • Wiggle it to the release the latches.
    • Separate the bezel from the cover.
  5. Dell Studio 1555 Display Replacement: 5 단계, 이미지 2개 중 1개 Dell Studio 1555 Display Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the four 3 mm screws securing the LCD using the #1 Phillips screwdriver.
  6. Dell Studio 1555 Display Replacement: 6 단계, 이미지 1개 중 1개
    • Separate the LCD assembly from the display cover so you will be able to access the webcam cable.
    • Unplug the camera cable.
  7. Dell Studio 1555 Display Replacement: 7 단계, 이미지 2개 중 1개 Dell Studio 1555 Display Replacement: 7 단계, 이미지 2개 중 2개
    • Place the LCD face down on the top cover.
    • Remove the sticky tape securing the video cable connector.
    • Unplug the video cable from the screen.
  8. Dell Studio 1555 Display Replacement: 8 단계, 이미지 3개 중 1개 Dell Studio 1555 Display Replacement: 8 단계, 이미지 3개 중 2개 Dell Studio 1555 Display Replacement: 8 단계, 이미지 3개 중 3개
    • Remove the LCD from the laptop.
    • Remove the four 3mm screws holding the mounting brackets using the #1 Phillips screwdriver. Two on each side.
    • You will have to transfer the mounting brackets to the new screen.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Josh Boone
회원 가입일: 10/10/16
586 평판
안내서 4개를 작성함
Sam Houston State, Team 12-3, Blackburne Fall 2016 Sam Houston State, Team 12-3, Blackburne Fall 2016 회원
SHSU-BLACKBURNE-F16S12G3
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 13
전체 시간: 1,739
