주요 콘텐츠로 건너뛰기
Dell Studio 1555 Keyboard Replacement
필요한 것
  1. Dell Studio 1555 Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn off and unplug the laptop.
    • Failure to properly turn off device before handling the battery could result in electrical shock.
    • Flip the laptop so the underside is facing up with the battery closest to you.
  2. Dell Studio 1555 Keyboard Replacement: 2 단계, 이미지 3개 중 1개 Dell Studio 1555 Keyboard Replacement: 2 단계, 이미지 3개 중 2개 Dell Studio 1555 Keyboard Replacement: 2 단계, 이미지 3개 중 3개
    • Slide the locking switch to the left to release the battery.
  3. Dell Studio 1555 Keyboard Replacement: 3 단계, 이미지 1개 중 1개
    • Gently pull the battery away from the device.
  4. Dell Studio 1555 Keyboard Replacement, Keyboard: 4 단계, 이미지 1개 중 1개
    • Remove the single 3mm screw underneath the battery with a #1 Phillips screw driver, which holds the media control cover.
  5. Dell Studio 1555 Keyboard Replacement: 5 단계, 이미지 2개 중 1개 Dell Studio 1555 Keyboard Replacement: 5 단계, 이미지 2개 중 2개
    • Flip the laptop over and flatten it out as much as possible.
    • Unsnap the media control cover from the laptop starting nearest to the display.
  6. Dell Studio 1555 Keyboard Replacement: 6 단계, 이미지 2개 중 1개 Dell Studio 1555 Keyboard Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the two 3mm screws with a #1 Phillips screwdriver, holding down the keyboard.
  7. Dell Studio 1555 Keyboard Replacement: 7 단계, 이미지 1개 중 1개
    • Slowly lift the keyboard away from the base.
    • If you pull to hard you risk breaking the keyboard cable connector from the motherboard.
  8. Dell Studio 1555 Keyboard Replacement: 8 단계, 이미지 3개 중 1개 Dell Studio 1555 Keyboard Replacement: 8 단계, 이미지 3개 중 2개 Dell Studio 1555 Keyboard Replacement: 8 단계, 이미지 3개 중 3개
    • Flip up the black tab on the keyboard ZIF connector and unplug the cable.
  9. Dell Studio 1555 Keyboard Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the keyboard
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Hunter Tuck
회원 가입일: 10/10/16
214 평판
안내서 1개를 작성함
Sam Houston State, Team 12-3, Blackburne Fall 2016 Sam Houston State, Team 12-3, Blackburne Fall 2016 회원
SHSU-BLACKBURNE-F16S12G3
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 19
전체 시간: 1,084
