주요 콘텐츠로 건너뛰기
Dell Studio 1737 Keyboard Replacement
필요한 것
  1. Dell Studio 1737 Keyboard Replacement, Battery: 1 단계, 이미지 1/2 Dell Studio 1737 Keyboard Replacement, Battery: 1 단계, 이미지 2/2
    • Slide the battery release slider all the way to the right and push the battery straight out of the back of the computer
  2. Dell Studio 1737 Keyboard Replacement, Keyboard: 2 단계, 이미지 1/1
    • Use a plastic opening tool to detach the internal clips (marked with red boxes in photo) and release the small plastic panel above the keyboard
    • This panel doesn't come off just yet, this step is just to make it easier when it comes time to remove it
  3. Dell Studio 1737 Keyboard Replacement: 3 단계, 이미지 1/1
    • Remove the 4mm ph1 screw under the battery
  4. Dell Studio 1737 Keyboard Replacement: 4 단계, 이미지 1/3 Dell Studio 1737 Keyboard Replacement: 4 단계, 이미지 2/3 Dell Studio 1737 Keyboard Replacement: 4 단계, 이미지 3/3
    • Pry black panel away from laptop body starting at the base of the screen
    • Be careful when flipping the panel over, as the panel is still attached by the fragile ribbon cable
    • Flip the panel over onto the keyboard
    • Detach the ribbon cable from the motherboard as shown
  5. Dell Studio 1737 Keyboard Replacement: 5 단계, 이미지 1/1
    • Starting at the top where you just removed the black panel, pry the black bezel away from the outside of the keyboard
  6. Dell Studio 1737 Keyboard Replacement: 6 단계, 이미지 1/2 Dell Studio 1737 Keyboard Replacement: 6 단계, 이미지 2/2
    • Use a small screwdriver to take out the 4 4mm ph1 screws along the top of the keyboard
    • Lift from the top of the keyboard and flip it over onto the palmrest
    • Again, be very careful of the ribbon cable attaching it, as these are easily damaged
  7. Dell Studio 1737 Keyboard Replacement: 7 단계, 이미지 1/2 Dell Studio 1737 Keyboard Replacement: 7 단계, 이미지 2/2
    • Remove the ribbon cable as shown
결론
다른 2명이 해당 안내서를 완성하였습니다.
Joseph Jacavone
회원 가입일: 03/10/17
785 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team S8-G4, Catania Spring 2017 UMass Dartmouth, Team S8-G4, Catania Spring 2017 회원
UMASSD-CATANIA-S17S8G4
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 7
전체 시간: 691
