주요 콘텐츠로 건너뛰기
Dell VRC100-R Motherboard Replacement
필요한 것
  1. Dell VRC100-R Motherboard Replacement, Battery: 1 단계, 이미지 1/3 Dell VRC100-R Motherboard Replacement, Battery: 1 단계, 이미지 2/3 Dell VRC100-R Motherboard Replacement, Battery: 1 단계, 이미지 3/3
    • Orient your controller so that the black ring is on the bottom and the buttons are facing away from yourself.
    • Place your thumb on the small arrow that is on the controller's battery cover and firmly push upwards.
    • Slide the cover off and separate it from the controller.
  2. Dell VRC100-R Motherboard Replacement: 2 단계, 이미지 1/2 Dell VRC100-R Motherboard Replacement: 2 단계, 이미지 2/2
    • Remove the right battery by pushing the positive end down and pulling the battery out toward yourself.
    • Repeat the procedure for the left battery.
  3. Dell VRC100-R Motherboard Replacement, Joystick: 3 단계, 이미지 1/3 Dell VRC100-R Motherboard Replacement, Joystick: 3 단계, 이미지 2/3 Dell VRC100-R Motherboard Replacement, Joystick: 3 단계, 이미지 3/3
    • Hold the joystick down with your left thumb to make space for the plastic opening tool.
    • Insert the plastic opening tool into the circle above the joystick and pry upwards to lift the front panel.
    • Slide the plastic opening tool around the perimeter until you can lift the front panel.
    • You may hear a popping noise when you pry off the front panel.
  4. Dell VRC100-R Motherboard Replacement: 4 단계, 이미지 1/2 Dell VRC100-R Motherboard Replacement: 4 단계, 이미지 2/2
    • Grab the joystick and pull away from the controller to remove it.
  5. Dell VRC100-R Motherboard Replacement, Daughterboard: 5 단계, 이미지 1/2 Dell VRC100-R Motherboard Replacement, Daughterboard: 5 단계, 이미지 2/2
    • Remove one 6mm Phillips #0 screw.
  6. Dell VRC100-R Motherboard Replacement: 6 단계, 이미지 1/2 Dell VRC100-R Motherboard Replacement: 6 단계, 이미지 2/2
    • Turn your controller over and orient it so that the thin side is on the top.
    • Remove four 4mm Phillips #0 screws.
  7. Dell VRC100-R Motherboard Replacement: 7 단계, 이미지 1/2 Dell VRC100-R Motherboard Replacement: 7 단계, 이미지 2/2
    • Turn your controller 90 degrees clockwise and insert a blue plastic opening tool into the crease of the back panel.
    • Push down on the end of the plastic opening tool closest to you to lift the panel up.
    • Slide the plastic opening tool around the perimeter of the back panel until you can remove it.
    • You may hear loud popping noises as the back panel separates from the controller.
  8. Dell VRC100-R Motherboard Replacement: 8 단계, 이미지 1/2 Dell VRC100-R Motherboard Replacement: 8 단계, 이미지 2/2
  9. Dell VRC100-R Motherboard Replacement: 9 단계, 이미지 1/3 Dell VRC100-R Motherboard Replacement: 9 단계, 이미지 2/3 Dell VRC100-R Motherboard Replacement: 9 단계, 이미지 3/3
    • Use the tip of the blue plastic opening tool or your fingernail to gently flip-up the white locking flap.
    • Make sure to only lift the flap and not the connector socket because the socket easily breaks off.
    • Grab the blue cable and pull away from the socket.
    • To reinstall, insert the blue cable into the connector and close the flap on the black line.
  10. Dell VRC100-R Motherboard Replacement: 10 단계, 이미지 1/3 Dell VRC100-R Motherboard Replacement: 10 단계, 이미지 2/3 Dell VRC100-R Motherboard Replacement: 10 단계, 이미지 3/3
    • Use the tip of a spudger or your fingernail to gently flip-up the small white flap holding the orange ribbon cable.
    • Grab the orange cable and pull away from the socket.
    • To reinstall, insert the orange cable into the connector and close the flap on the white line.
  11. Dell VRC100-R Motherboard Replacement: 11 단계, 이미지 1/2 Dell VRC100-R Motherboard Replacement: 11 단계, 이미지 2/2
    • Place two fingers on the perimeter of the daughterboard and lift it away from the controller.
  12. Dell VRC100-R Motherboard Replacement, Motherboard: 12 단계, 이미지 1/2 Dell VRC100-R Motherboard Replacement, Motherboard: 12 단계, 이미지 2/2
    • Remove two black 6mm Phillips #0 screws.
  13. Dell VRC100-R Motherboard Replacement: 13 단계, 이미지 1/2 Dell VRC100-R Motherboard Replacement: 13 단계, 이미지 2/2
    • Pinch the black ring on the top of your controller and pull toward yourself to disconnect it.
    • The ring may slightly pop as it disconnects from the controller body.
  14. Dell VRC100-R Motherboard Replacement: 14 단계, 이미지 1/2 Dell VRC100-R Motherboard Replacement: 14 단계, 이미지 2/2
    • Grab the black and red wires attached to the motherboard and wiggle the connector out of the socket.
  15. Dell VRC100-R Motherboard Replacement: 15 단계, 이미지 1/2 Dell VRC100-R Motherboard Replacement: 15 단계, 이미지 2/2
    • Remove three 3mm Phillips #0 screws.
  16. Dell VRC100-R Motherboard Replacement: 16 단계, 이미지 1/2 Dell VRC100-R Motherboard Replacement: 16 단계, 이미지 2/2
    • Insert your finger underneath the black plastic "V" and scoop up to remove it.
  17. Dell VRC100-R Motherboard Replacement: 17 단계, 이미지 1/2 Dell VRC100-R Motherboard Replacement: 17 단계, 이미지 2/2
    • Remove two 4mm Phillips #0 screws.
  18. Dell VRC100-R Motherboard Replacement: 18 단계, 이미지 1/1
    • Pinch the orange ribbon cable and pull toward yourself to remove the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Steven Pineda
회원 가입일: 04/16/18
881 평판
안내서 3개 작성하였습니다
Cal Poly, Team S18-G3, Livingston Spring 2018 Cal Poly, Team S18-G3, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S18G3
4 회원들
안내서 5개 작성하였습니다
댓글 4개
Thanks, using this as a tear down guide.
Gamerz Crafted - 답글
Hi, do anyone know where this motherboard can be purchased?
John Franco - 답글
does anybody know where I can buy the ribbon cable, between the two boards. in Step 10
Tim Bury - 답글
where can i buy the motherboard?
José Yoctán Leyva Román - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 15
전체 시간: 1,474
