주요 콘텐츠로 건너뛰기
Dell VRP100 Auxiliary Cord Replacement
필요한 것
  1. Dell VRP100 Auxiliary Cord Replacement, Cover Panel: 1 단계, 이미지 1/3 Dell VRP100 Auxiliary Cord Replacement, Cover Panel: 1 단계, 이미지 2/3 Dell VRP100 Auxiliary Cord Replacement, Cover Panel: 1 단계, 이미지 3/3
    • Remove the black foam padding by peeling away slowly.
    • Remove the front and back padding from the headset by peeling away slowly.
  2. Dell VRP100 Auxiliary Cord Replacement: 2 단계, 이미지 1/1
    • Remove the six 5.5mm PH000 screws from the cover by rotating counter-clockwise.
    • Cover panel may need to be pushed in before inserting screws.
  3. Dell VRP100 Auxiliary Cord Replacement: 3 단계, 이미지 1/3 Dell VRP100 Auxiliary Cord Replacement: 3 단계, 이미지 2/3 Dell VRP100 Auxiliary Cord Replacement: 3 단계, 이미지 3/3
    • Remove the cover using one of the plastic opening tools, and then carefully pull it from the casing.
  4. Dell VRP100 Auxiliary Cord Replacement: 4 단계, 이미지 1/3 Dell VRP100 Auxiliary Cord Replacement: 4 단계, 이미지 2/3 Dell VRP100 Auxiliary Cord Replacement: 4 단계, 이미지 3/3
    • Carefully remove the lens and motherboard assembly from the white casing.
  5. Dell VRP100 Auxiliary Cord Replacement, Auxiliary Cord: 5 단계, 이미지 1/3 Dell VRP100 Auxiliary Cord Replacement, Auxiliary Cord: 5 단계, 이미지 2/3 Dell VRP100 Auxiliary Cord Replacement, Auxiliary Cord: 5 단계, 이미지 3/3
    • Separate the external connector of the auxiliary cord.
    • A spudger may be needed to separate the connector.
  6. Dell VRP100 Auxiliary Cord Replacement: 6 단계, 이미지 1/2 Dell VRP100 Auxiliary Cord Replacement: 6 단계, 이미지 2/2
    • Remove the four 2.5mm PH000 screws by rotating counter-clockwise.
    • Separate the lens housing from the motherboard panel.
  7. Dell VRP100 Auxiliary Cord Replacement: 7 단계, 이미지 1/3 Dell VRP100 Auxiliary Cord Replacement: 7 단계, 이미지 2/3 Dell VRP100 Auxiliary Cord Replacement: 7 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • In the top right corner of the motherboard panel, peel back the yellow tape covering the bundled auxiliary cable connector using tweezers.
    • Carefully pull out the bundled cable connectors.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Chris Grabow
회원 가입일: 10/08/18
285 평판
안내서 2개 작성하였습니다
Cal Poly, Team S17-G1, White Fall 2018 Cal Poly, Team S17-G1, White Fall 2018 회원
CPSU-WHITE-F18S17G1
4 회원들
안내서 12개 작성하였습니다
댓글 한 개
Hello, where i can buy the aux cable?
Domenico Rescigno - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 13
전체 시간: 715
