주요 콘텐츠로 건너뛰기
Dell VRP100 Camera Replacement
필요한 것
  1. Dell VRP100 Camera Replacement, Cover Panel: 1 단계, 이미지 1/3 Dell VRP100 Camera Replacement, Cover Panel: 1 단계, 이미지 2/3 Dell VRP100 Camera Replacement, Cover Panel: 1 단계, 이미지 3/3
    • Remove the black foam padding by peeling away slowly.
    • Remove the front and back padding from the headset by peeling away slowly.
  2. Dell VRP100 Camera Replacement: 2 단계, 이미지 1/1
    • Remove the six 5.5mm PH000 screws from the cover by rotating counter-clockwise.
    • Cover panel may need to be pushed in before inserting screws.
  3. Dell VRP100 Camera Replacement: 3 단계, 이미지 1/3 Dell VRP100 Camera Replacement: 3 단계, 이미지 2/3 Dell VRP100 Camera Replacement: 3 단계, 이미지 3/3
    • Remove the cover using one of the plastic opening tools, and then carefully pull it from the casing.
  4. Dell VRP100 Camera Replacement: 4 단계, 이미지 1/3 Dell VRP100 Camera Replacement: 4 단계, 이미지 2/3 Dell VRP100 Camera Replacement: 4 단계, 이미지 3/3
    • Carefully remove the lens and motherboard assembly from the white casing.
  5. Dell VRP100 Camera Replacement, Camera: 5 단계, 이미지 1/3 Dell VRP100 Camera Replacement, Camera: 5 단계, 이미지 2/3 Dell VRP100 Camera Replacement, Camera: 5 단계, 이미지 3/3
    • Remove the four 2.5mm PH000 screws by rotating counter-clockwise.
    • Separate the lens housing from the motherboard panel.
  6. Dell VRP100 Camera Replacement: 6 단계, 이미지 1/2 Dell VRP100 Camera Replacement: 6 단계, 이미지 2/2
    • Remove the two 2.5mm PH000 screws from the motherboard by rotating counter-clockwise.
    • Remove the four 3.9mm PH000 screws from the white casing by rotating counter-clockwise.
  7. Dell VRP100 Camera Replacement: 7 단계, 이미지 1/2 Dell VRP100 Camera Replacement: 7 단계, 이미지 2/2
    • Remove the flat-topped connector by lifting it straight up from the motherboard.
    • Carefully remove the camera from the casing with the blunt nose tweezers by holding onto the copper tape.
    • To reinstall, line up the connectors and firmly push until you hear a pop.
결론
Lauren Monzon
회원 가입일: 10/08/18
217 평판
안내서 2개 작성하였습니다
Cal Poly, Team S17-G1, White Fall 2018 Cal Poly, Team S17-G1, White Fall 2018 회원
CPSU-WHITE-F18S17G1
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 365
