소개
The internal screen should be replaced is if there is no display showing. The screen may be damaged from cracks or scratches. You should be cautious when reassembling the headset, as to not damage the new screen.
필요한 것
Remove the black foam padding by peeling away slowly.
Remove the front and back padding from the headset by peeling away slowly.
Remove the four 2.5 mm PH000 screws by rotating counter-clockwise.
Separate the lenses from the motherboard panel.
거의 끝나갑니다!
결론
