주요 콘텐츠로 건너뛰기
Dell Venue 11 Pro Speakers Replacement
필요한 것
  1. Dell Venue 11 Pro Speakers Replacement, Battery: 1 단계, 이미지 1/3 Dell Venue 11 Pro Speakers Replacement, Battery: 1 단계, 이미지 2/3 Dell Venue 11 Pro Speakers Replacement, Battery: 1 단계, 이미지 3/3
    • Turn your device over to the backside. On the notch at the bottom portion of the tablet, use your fingers to lift up the back cover.
  2. Dell Venue 11 Pro Speakers Replacement: 2 단계, 이미지 1/3 Dell Venue 11 Pro Speakers Replacement: 2 단계, 이미지 2/3 Dell Venue 11 Pro Speakers Replacement: 2 단계, 이미지 3/3
    • Below the battery pack, there are two lock mechanisms. Push EACH lock to the LEFT until it makes a click noise. Lift the battery from the bottom up and remove.
  3. Dell Venue 11 Pro Speakers Replacement, Frame: 3 단계, 이미지 1/2 Dell Venue 11 Pro Speakers Replacement, Frame: 3 단계, 이미지 2/2
    • Use your Philips #000 screwdriver to unscrew the fourteen 2.5 mm screws marked on the tablet.
    • These screws are extremely small. Place the screws aside in a container or on your magnetic mat to prevent accidental loss.
  4. Dell Venue 11 Pro Speakers Replacement: 4 단계, 이미지 1/3 Dell Venue 11 Pro Speakers Replacement: 4 단계, 이미지 2/3 Dell Venue 11 Pro Speakers Replacement: 4 단계, 이미지 3/3
    • Slide the cover on the two middle ribbon cables out to remove it. It should uncover the orange cable connectors.
  5. Dell Venue 11 Pro Speakers Replacement: 5 단계, 이미지 1/3 Dell Venue 11 Pro Speakers Replacement: 5 단계, 이미지 2/3 Dell Venue 11 Pro Speakers Replacement: 5 단계, 이미지 3/3
    • To disconnect the left ribbon cable from the motherboard, place the flat end of your spudger under the edge of the pop connector and pry the connector straight up.
    • The two ribbon cables connect the keyboard attachment ports to the motherboard. Damage to either cables can induce problems with the Dell mobile keyboard.
  6. Dell Venue 11 Pro Speakers Replacement: 6 단계, 이미지 1/3 Dell Venue 11 Pro Speakers Replacement: 6 단계, 이미지 2/3 Dell Venue 11 Pro Speakers Replacement: 6 단계, 이미지 3/3
    • The right ribbon cable has a ZIF connector. Use the flat end of your spudger to lift up the small locking flap, then pull out the cable.
    • Pulling the ribbon cable out before unlocking the connector can potentially damage the cable.
  7. Dell Venue 11 Pro Speakers Replacement: 7 단계, 이미지 1/1
    • There are adhesive strips between the device and the two ribbon cables we disconnected. Pull each cable away from the device just enough to break the adhesive bonds.
  8. Dell Venue 11 Pro Speakers Replacement: 8 단계, 이미지 1/3 Dell Venue 11 Pro Speakers Replacement: 8 단계, 이미지 2/3 Dell Venue 11 Pro Speakers Replacement: 8 단계, 이미지 3/3
    • Use your pin punch driver to push into the hole on the sim card, then pull out the sim tray.
  9. Dell Venue 11 Pro Speakers Replacement: 9 단계, 이미지 1/3 Dell Venue 11 Pro Speakers Replacement: 9 단계, 이미지 2/3 Dell Venue 11 Pro Speakers Replacement: 9 단계, 이미지 3/3
    • Insert your plastic opening tool between the screen and frame, and run the tool around the edges to separate the frame from the tablet.
  10. Dell Venue 11 Pro Speakers Replacement, Speakers: 10 단계, 이미지 1/1
    • Locate the right and left speakers to be replaced. For this guide, we will start with the left speaker, then the right speaker.
    • If you are replacing the motherboard by itself, then skip steps 17 and 19.
  11. Dell Venue 11 Pro Speakers Replacement: 11 단계, 이미지 1/3 Dell Venue 11 Pro Speakers Replacement: 11 단계, 이미지 2/3 Dell Venue 11 Pro Speakers Replacement: 11 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Using a pair of tweezers, detach the red and white cable connector from the circuit board.
    • The laptop is rotated 130 degrees counterclockwise for better viewing.
  12. Dell Venue 11 Pro Speakers Replacement: 12 단계, 이미지 1/2 Dell Venue 11 Pro Speakers Replacement: 12 단계, 이미지 2/2
    • Once the cable has been detached, use your fingers to lift the right speaker upwards to remove it.
  13. Dell Venue 11 Pro Speakers Replacement: 13 단계, 이미지 1/3 Dell Venue 11 Pro Speakers Replacement: 13 단계, 이미지 2/3 Dell Venue 11 Pro Speakers Replacement: 13 단계, 이미지 3/3
    • On the right side, use a pair of tweezers to detach the red and white cables from the connector.
    • This device is rotated 130 degrees clockwise for better viewing.
  14. Dell Venue 11 Pro Speakers Replacement: 14 단계, 이미지 1/1
    • Lift the right speaker upwards using your fingers to remove it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Carolina Gushi
회원 가입일: 10/04/17
339 평판
안내서 2개 작성하였습니다
USF Tampa, Team S3-G1, Nance Fall 2017 USF Tampa, Team S3-G1, Nance Fall 2017 회원
USFT-NANCE-F17S3G1
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 9
전체 시간: 521
