주요 콘텐츠로 건너뛰기
Dell Venue 7 Battery Replacement
필요한 것
  1. Dell Venue 7 Battery Replacement, Rear Case: 1 단계, 이미지 1/2 Dell Venue 7 Battery Replacement, Rear Case: 1 단계, 이미지 2/2
    • Use a spudger or your fingers to pry off the back case.
    • If your case is badly damaged, use caution because the fragments may be sharp.
  2. Dell Venue 7 Battery Replacement, Battery: 2 단계, 이미지 1/1
    • Gently disconnect the battery from the motherboard using your fingers or a pair of tweezers.
  3. Dell Venue 7 Battery Replacement: 3 단계, 이미지 1/1
    • Remove the battery by pulling it from the edges and carefully peeling it off of the base.
    • There is adhesive keeping the battery in place, so don't be afraid to use a little extra force.
    • Do not bend or warp the battery in any way as it can be a fire hazard.
결론
chaveza
회원 가입일: 01/20/15
101 평판
안내서 1개 작성함
USF Tampa, Team 11-4, Blackwell Winter 2015 USF Tampa, Team 11-4, Blackwell Winter 2015 회원
USFT-BLACKWELL-W15S11G4
4 회원들
안내서 10개 작성하였습니다
댓글 4개
I am purchase dell vaneu 7 8gb internal memory like_ion battery 15.17 wh EU 4100 price
Avind Kumar agrawal - 답글
Dell vanue 7 tablat I want like_battery 15.17wh EU 4100 mah
Prices dell venue 7 li_I on battery 15.17 wh EU 4100mah
From were to purchase battery
shriyash Mhatre - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 7,366
