소개
Many components are connected to the motherboard so confirm that all of the components work before you decide to replace the whole motherboard.
필요한 것
Gently disconnect the battery from the motherboard using your fingers or a pair of tweezers.
Disconnect the two remaining connections on the motherboard.
To remove the first connector, lift up the clasp and remove the ribbon cable.
To remove the second one, use a spudger to gently pry the connector from the motherboard.
다른 8명이 해당 안내서를 완성하였습니다.
댓글 2개
unable to open the lock, can the mother board be changed
Great article.
