주요 콘텐츠로 건너뛰기
Dell Venue 7 Motherboard Replacement
필요한 것
  1. Dell Venue 7 Motherboard Replacement, Rear Case: 1 단계, 이미지 1/2 Dell Venue 7 Motherboard Replacement, Rear Case: 1 단계, 이미지 2/2
    • Use a spudger or your fingers to pry off the back case.
    • If your case is badly damaged, use caution because the fragments may be sharp.
  2. Dell Venue 7 Motherboard Replacement, Battery: 2 단계, 이미지 1/1
    • Gently disconnect the battery from the motherboard using your fingers or a pair of tweezers.
  3. Dell Venue 7 Motherboard Replacement: 3 단계, 이미지 1/1
    • Remove the battery by pulling it from the edges and carefully peeling it off of the base.
    • There is adhesive keeping the battery in place, so don't be afraid to use a little extra force.
    • Do not bend or warp the battery in any way as it can be a fire hazard.
  4. Dell Venue 7 Motherboard Replacement, Rear Facing Camera: 4 단계, 이미지 1/1
    • Use a spudger to disconnect the camera from the motherboard.
  5. Dell Venue 7 Motherboard Replacement: 5 단계, 이미지 1/1
    • Remove the camera from the device.
  6. Dell Venue 7 Motherboard Replacement, Speaker: 6 단계, 이미지 1/2 Dell Venue 7 Motherboard Replacement, Speaker: 6 단계, 이미지 2/2
    • Use a spudger to remove the ribbon cable that is around the speaker wire.
  7. Dell Venue 7 Motherboard Replacement: 7 단계, 이미지 1/2 Dell Venue 7 Motherboard Replacement: 7 단계, 이미지 2/2
    • Disconnect the speaker wire from the motherboard by prying the connector upwards with the spudger.
  8. Dell Venue 7 Motherboard Replacement: 8 단계, 이미지 1/1
    • Remove the plastic covering on the speaker.
  9. Dell Venue 7 Motherboard Replacement: 9 단계, 이미지 1/2 Dell Venue 7 Motherboard Replacement: 9 단계, 이미지 2/2
    • Gently pull on the wire and remove the speaker.
    When I was pulling the speaker out the wire had broken where can I get the speaker?
    ginovirgiltthiruchudar - 답글
  10. Dell Venue 7 Motherboard Replacement, Motherboard: 10 단계, 이미지 1/3 Dell Venue 7 Motherboard Replacement, Motherboard: 10 단계, 이미지 2/3 Dell Venue 7 Motherboard Replacement, Motherboard: 10 단계, 이미지 3/3
    • Disconnect the two remaining connections on the motherboard.
    • To remove the first connector, lift up the clasp and remove the ribbon cable.
    • To remove the second one, use a spudger to gently pry the connector from the motherboard.
  11. Dell Venue 7 Motherboard Replacement: 11 단계, 이미지 1/2 Dell Venue 7 Motherboard Replacement: 11 단계, 이미지 2/2
    • Remove all 8 of the 2.1mm Phillips head screws from the motherboard.
  12. Dell Venue 7 Motherboard Replacement: 12 단계, 이미지 1/1
    • Lift and remove the motherboard from the device.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Stephen Rousseau
회원 가입일: 01/20/15
663 평판
안내서 4개 작성하였습니다
USF Tampa, Team 11-4, Blackwell Winter 2015 USF Tampa, Team 11-4, Blackwell Winter 2015 회원
USFT-BLACKWELL-W15S11G4
4 회원들
안내서 10개 작성하였습니다
댓글 2개
unable to open the lock, can the mother board be changed
Amitabh Mishra - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 4,409
