이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Gently disconnect the battery from the motherboard using your fingers or a pair of tweezers.
Remove the battery by pulling it from the edges and carefully peeling it off of the base.
Use a spudger to remove the ribbon cable that is around the speaker wire.
Disconnect the speaker wire from the motherboard by prying the connector upwards with the spudger.
Disconnect the two remaining connections on the motherboard.
To remove the first connector, lift up the clasp and remove the ribbon cable.
To remove the second one, use a spudger to gently pry the connector from the motherboard.
다른 8명이 해당 안내서를 완성하였습니다.
댓글 2개
unable to open the lock, can the mother board be changed
Great article.
