주요 콘텐츠로 건너뛰기
Dell Venue 7 Rear Facing Camera Replacement
필요한 것
  1. Dell Venue 7 Rear Facing Camera Replacement, Rear Case: 1 단계, 이미지 1/2 Dell Venue 7 Rear Facing Camera Replacement, Rear Case: 1 단계, 이미지 2/2
    • Use a spudger or your fingers to pry off the back case.
    • If your case is badly damaged, use caution because the fragments may be sharp.
  2. Dell Venue 7 Rear Facing Camera Replacement, Battery: 2 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Gently disconnect the battery from the motherboard using your fingers or a pair of tweezers.
  3. Dell Venue 7 Rear Facing Camera Replacement: 3 단계, 이미지 1/1
    • Remove the battery by pulling it from the edges and carefully peeling it off of the base.
    • There is adhesive keeping the battery in place, so don't be afraid to use a little extra force.
    • Do not bend or warp the battery in any way as it can be a fire hazard.
  4. Dell Venue 7 Rear Facing Camera Replacement, Rear Facing Camera: 4 단계, 이미지 1/1
    • Use a spudger to disconnect the camera from the motherboard.
  5. Dell Venue 7 Rear Facing Camera Replacement: 5 단계, 이미지 1/1
    • Remove the camera from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Stephen Rousseau
회원 가입일: 01/20/15
663 평판
안내서 4개 작성하였습니다
USF Tampa, Team 11-4, Blackwell Winter 2015 USF Tampa, Team 11-4, Blackwell Winter 2015 회원
USFT-BLACKWELL-W15S11G4
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 473
