주요 콘텐츠로 건너뛰기
Dell Venue 8 7840 Screen Replacement
필요한 것
  1. Dell Venue 8 7840 Screen Replacement, Screen: 1 단계, 이미지 1/1
    • Make sure your device is turned off. Leaving it turned on may cause an electric shock.
    • Face the device with the screen towards you.
  2. Dell Venue 8 7840 Screen Replacement: 2 단계, 이미지 1/1
    • With a plastic opening tool, pry open the bottom left corner of the screen.
    • The screen is tightly attached to the tablet, so you may have to use a metal spudger to pry it open if the plastic spudger does not do the task.
  3. Dell Venue 8 7840 Screen Replacement: 3 단계, 이미지 1/1
    • Next, pry open the top left corner of the screen.
  4. Dell Venue 8 7840 Screen Replacement: 4 단계, 이미지 1/1
    • Then, pry open the top right corner of the screen.
  5. Dell Venue 8 7840 Screen Replacement: 5 단계, 이미지 1/1
    • Lastly, pry open the bottom right corner of the screen.
  6. Dell Venue 8 7840 Screen Replacement: 6 단계, 이미지 1/1
    • Once you have pried open all the corners of the tablet, carefully open the screen from the right side of the tablet.
    • Do not try and open the screen from the left side of the tablet, because the screen is attached on the left side of the tablet; doing this can damage the tablet.
  7. Dell Venue 8 7840 Screen Replacement: 7 단계, 이미지 1/1
    • Once the tablet is opened, locate the connector.
  8. Dell Venue 8 7840 Screen Replacement: 8 단계, 이미지 1/1
    • Disconnect the connector from the tablet.
결론
Donnelle January
회원 가입일: 09/12/16
429 평판
안내서 3개 작성하였습니다
USF Tampa, Team 6-5, Remmell Fall 2016 USF Tampa, Team 6-5, Remmell Fall 2016 회원
USFT-REMMELL-F16S6G5
3 회원들
안내서 6개 작성하였습니다
댓글 3개
i wanted to replace the battery but dont know how to pry the screen open, is it attached with glue? thanks in advance.
dengzc - 답글
Where can I find a replacement screen for this device?
Karim Mohamed - 답글
Is the OLED connected with EDP 30=pin FPC?
Ron King - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 1,391
