주요 콘텐츠로 건너뛰기
Dell Venue 8 Speaker Replacement
필요한 것
  1. Dell Venue 8 Speaker Replacement, Rear Case/Midframe: 1 단계, 이미지 1/1
    • Hold the device with the screen facing up. Gently wedge your plastic opening tool into the crease, and run it along the perimeter of the case
    • You will hear click sounds as the clips unhinge
    • Remove the back panel of the device.
  2. Dell Venue 8 Speaker Replacement: 2 단계, 이미지 1/3 Dell Venue 8 Speaker Replacement: 2 단계, 이미지 2/3 Dell Venue 8 Speaker Replacement: 2 단계, 이미지 3/3
    • Remove the 14 screws with the T-5 Torx screwdriver. (11 black 3.6mm screws, and three 4.45mm screws)
    • The silver screws are marked with an "S" or a sticker [S1.6(Silver)] See the corrected image
    • 4.45mm Silver screws
    • 3.6mm Black screws
    • Gently snap the perimeter clips open, and remove the internal plastic case.
  3. Dell Venue 8 Speaker Replacement, Speaker: 3 단계, 이미지 1/1
    • Using your plastic opening tool, unclip the speaker connection from the logic board.
    • Caution: Pull directly up, not out, on the connection
  4. Dell Venue 8 Speaker Replacement: 4 단계, 이미지 1/1
    • Remove the speaker by placing using your plastic opening tool in the gap on the top of the speaker and prying it up.
    • The speaker is held on by light adhesive
결론
Andrea
회원 가입일: 02/19/15
1,071 평판
안내서 5개 작성하였습니다
USF Tampa, Team 9-2, Leahy Winter 2015 USF Tampa, Team 9-2, Leahy Winter 2015 회원
USFT-LEAHY-W15S9G2
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 6
전체 시간: 691
