주요 콘텐츠로 건너뛰기
Dell Vostro 1320 Fan Replacement
필요한 것
  1. Dell Vostro 1320 Fan Replacement, Fan: 1 단계, 이미지 1/2 Dell Vostro 1320 Fan Replacement, Fan: 1 단계, 이미지 2/2
    • Turn the laptop over so that the bottom of it is exposed.
    • The section of the computer that we need to access is the right panel. You need to start by using the J00 bit attachment to the Bit Driver to unscrew the screw
  2. Dell Vostro 1320 Fan Replacement: 2 단계, 이미지 1/3 Dell Vostro 1320 Fan Replacement: 2 단계, 이미지 2/3 Dell Vostro 1320 Fan Replacement: 2 단계, 이미지 3/3
    • Use the flat Metal Spudger to open the plastic panel.
    • If the panel does not open right away try placing the flat Metal Spudger to the adjacent or opposite side of the plastic panel.
  3. Dell Vostro 1320 Fan Replacement: 3 단계, 이미지 1/1
    • Unplug the wire connecting the fan to the computer by pulling straight up on the connector.
  4. Dell Vostro 1320 Fan Replacement: 4 단계, 이미지 1/2 Dell Vostro 1320 Fan Replacement: 4 단계, 이미지 2/2
    • Remove the two black screws holding the fan down by using the phillips head screwdriver.
  5. Dell Vostro 1320 Fan Replacement: 5 단계, 이미지 1/2 Dell Vostro 1320 Fan Replacement: 5 단계, 이미지 2/2
    • Gently pull the fan away from the side of the computer. Lift it out completely.
    • At this point you can now blow all the dust out of your fan and the copper heatsink.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Christie Lloyd
회원 가입일: 08/26/15
431 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 15
전체 시간: 679
