주요 콘텐츠로 건너뛰기
Dell Vostro 1400 RAM Replacement
필요한 것
  1. Dell Vostro 1400 RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Be sure the power is off and all cables are unplugged from the device before starting.
    • After flipping over the laptop, the battery is on the bottom side of the laptop.
    • Find the tabs on both the left and right side of the battery.
  2. Dell Vostro 1400 RAM Replacement: 2 단계, 이미지 1/1
    • Push tabs toward the outside of the laptop until they lock in place.
  3. Dell Vostro 1400 RAM Replacement: 3 단계, 이미지 1/2 Dell Vostro 1400 RAM Replacement: 3 단계, 이미지 2/2
    • Push the battery forward to eject it from the laptop.
  4. Dell Vostro 1400 RAM Replacement, RAM: 4 단계, 이미지 1/2 Dell Vostro 1400 RAM Replacement, RAM: 4 단계, 이미지 2/2
    • Make sure the laptop is turned off and all cables are unplugged.
    • Loosen the three 3 mm screws on the RAM cover.
    • Screws will not completely come out.
    • Lift the cover and remove it from the laptop.
  5. Dell Vostro 1400 RAM Replacement: 5 단계, 이미지 1/2 Dell Vostro 1400 RAM Replacement: 5 단계, 이미지 2/2
    • Pull tabs apart on both the top and bottom of the memory card.
    • Lift memory card and remove it from the laptop.
    • Repeat the process for the second memory card.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
David Hogg
회원 가입일: 03/20/17
727 평판
안내서 5개 작성하였습니다
Texas Tech, Team S8-G2, Bennett Spring 2017 Texas Tech, Team S8-G2, Bennett Spring 2017 회원
TTU-BENNETT-S17S8G2
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 8
전체 시간: 368
