주요 콘텐츠로 건너뛰기
Dell Vostro 1400 Screen Replacement
필요한 것
  1. Dell Vostro 1400 Screen Replacement, Battery: 1 단계, 이미지 1/1
    • Be sure the power is off and all cables are unplugged from the device before starting.
    • After flipping over the laptop, the battery is on the bottom side of the laptop.
    • Find the tabs on both the left and right side of the battery.
  2. Dell Vostro 1400 Screen Replacement: 2 단계, 이미지 1/1
    • Push tabs toward the outside of the laptop until they lock in place.
  3. Dell Vostro 1400 Screen Replacement: 3 단계, 이미지 1/2 Dell Vostro 1400 Screen Replacement: 3 단계, 이미지 2/2
    • Push the battery forward to eject it from the laptop.
  4. Dell Vostro 1400 Screen Replacement, Screen: 4 단계, 이미지 1/1
    • Please make sure your device is completely turned off and everything is unplugged from the device
    • Open the laptop.
  5. Dell Vostro 1400 Screen Replacement: 5 단계, 이미지 1/2 Dell Vostro 1400 Screen Replacement: 5 단계, 이미지 2/2
    • Remove the 6 screw hole covers surrounding the screen.
    • Remove the 6 screws that were underneath the screw covers.
  6. Dell Vostro 1400 Screen Replacement: 6 단계, 이미지 1/2 Dell Vostro 1400 Screen Replacement: 6 단계, 이미지 2/2
    • Carefully remove the plastic surrounding the screen by pulling off, starting at the bottom.
    • Remove the two (2.5mm x 5mm) screws at the top, by the camera.
  7. Dell Vostro 1400 Screen Replacement: 7 단계, 이미지 1/2 Dell Vostro 1400 Screen Replacement: 7 단계, 이미지 2/2
    • Remove the two 5mm screws from the camera above the screen.
    • Remove the two 5mm screws from the bottom of the screen.
  8. Dell Vostro 1400 Screen Replacement: 8 단계, 이미지 1/2 Dell Vostro 1400 Screen Replacement: 8 단계, 이미지 2/2
    • Carefully remove the screen from the back cover.
  9. Dell Vostro 1400 Screen Replacement: 9 단계, 이미지 1/2 Dell Vostro 1400 Screen Replacement: 9 단계, 이미지 2/2
    • Lift up the black tag holding the camera and cable together.
    • Unplug the camera from the cable.
  10. Dell Vostro 1400 Screen Replacement: 10 단계, 이미지 1/3 Dell Vostro 1400 Screen Replacement: 10 단계, 이미지 2/3 Dell Vostro 1400 Screen Replacement: 10 단계, 이미지 3/3
    • Unplug the two cables connected to the screen.
  11. Dell Vostro 1400 Screen Replacement: 11 단계, 이미지 1/2 Dell Vostro 1400 Screen Replacement: 11 단계, 이미지 2/2
    • Remove the six 3mm screws on each side of the screen.
    • Remove the railing on each side of the screen.
    • The railing will be marked "L" for left side or "R" for the right. This should assist in reassembly.
결론
다른 2명이 해당 안내서를 완성하였습니다.
David Hogg
회원 가입일: 03/20/17
727 평판
안내서 5개 작성하였습니다
Texas Tech, Team S8-G2, Bennett Spring 2017 Texas Tech, Team S8-G2, Bennett Spring 2017 회원
TTU-BENNETT-S17S8G2
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 12
전체 시간: 650
