주요 콘텐츠로 건너뛰기
Dell Vostro 1400 Speakers Replacement
필요한 것
  1. Dell Vostro 1400 Speakers Replacement, Battery: 1 단계, 이미지 1/1
    • Be sure the power is off and all cables are unplugged from the device before starting.
    • After flipping over the laptop, the battery is on the bottom side of the laptop.
    • Find the tabs on both the left and right side of the battery.
  2. Dell Vostro 1400 Speakers Replacement: 2 단계, 이미지 1/1
    • Push tabs toward the outside of the laptop until they lock in place.
  3. Dell Vostro 1400 Speakers Replacement: 3 단계, 이미지 1/2 Dell Vostro 1400 Speakers Replacement: 3 단계, 이미지 2/2
    • Push the battery forward to eject it from the laptop.
  4. Dell Vostro 1400 Speakers Replacement, Hard Drive: 4 단계, 이미지 1/2 Dell Vostro 1400 Speakers Replacement, Hard Drive: 4 단계, 이미지 2/2
    • Please ensure that your device is turned off and everything is unplugged before working on it.
    • Unscrew both screws on the hard drive panel until the panel is able to be removed.
    • The screws will not come off of the panel.
    • Once screws have been loosened, remove the panel from the laptop.
  5. Dell Vostro 1400 Speakers Replacement: 5 단계, 이미지 1/1
    • Remove the hard drive by pulling up on the black tab on the right side of the hard drive.
  6. Dell Vostro 1400 Speakers Replacement, RAM: 6 단계, 이미지 1/2 Dell Vostro 1400 Speakers Replacement, RAM: 6 단계, 이미지 2/2
    • Make sure the laptop is turned off and all cables are unplugged.
    • Loosen the three 3 mm screws on the RAM cover.
    • Screws will not completely come out.
    • Lift the cover and remove it from the laptop.
  7. Dell Vostro 1400 Speakers Replacement: 7 단계, 이미지 1/2 Dell Vostro 1400 Speakers Replacement: 7 단계, 이미지 2/2
    • Pull tabs apart on both the top and bottom of the memory card.
    • Lift memory card and remove it from the laptop.
    • Repeat the process for the second memory card.
  8. Dell Vostro 1400 Speakers Replacement, Speakers: 8 단계, 이미지 1/3 Dell Vostro 1400 Speakers Replacement, Speakers: 8 단계, 이미지 2/3 Dell Vostro 1400 Speakers Replacement, Speakers: 8 단계, 이미지 3/3
    • Make sure device is turned off
    • Loosen the 3 screws holding down the panel for the CPU processor door.
    • Loosen the 4 heat sink screws and lift the heat sink away from the motherboard.
  9. Dell Vostro 1400 Speakers Replacement: 9 단계, 이미지 1/2 Dell Vostro 1400 Speakers Replacement: 9 단계, 이미지 2/2
    • Use a flat head screw driver to turn the CPU locking screw counter clockwise to 180 degrees.
    • Lift CPU processor away from the motherboard
  10. Dell Vostro 1400 Speakers Replacement: 10 단계, 이미지 1/2 Dell Vostro 1400 Speakers Replacement: 10 단계, 이미지 2/2
    • Remove the seventeen 8mm bottom base screws.
    • Remove the two 8mm screws from the back.
  11. Dell Vostro 1400 Speakers Replacement: 11 단계, 이미지 1/2 Dell Vostro 1400 Speakers Replacement: 11 단계, 이미지 2/2
    • Remove the three 3mm bottom base screws.
    • Remove the 5mm bottom base screw.
  12. Dell Vostro 1400 Speakers Replacement: 12 단계, 이미지 1/2 Dell Vostro 1400 Speakers Replacement: 12 단계, 이미지 2/2
    • Turn over the laptop and open it.
    • Using a flat head screw driver, pry up the power button cover starting right to left.
  13. Dell Vostro 1400 Speakers Replacement: 13 단계, 이미지 1/2 Dell Vostro 1400 Speakers Replacement: 13 단계, 이미지 2/2
    • Unscrew the (2) 2mm x 3mm screws.
    • Carefully lift the keyboard and hold it over the power button.
  14. Dell Vostro 1400 Speakers Replacement: 14 단계, 이미지 1/3 Dell Vostro 1400 Speakers Replacement: 14 단계, 이미지 2/3 Dell Vostro 1400 Speakers Replacement: 14 단계, 이미지 3/3
    • Carefully lift up the blue latch on the keyboard cable connector and slide the cable out.
  15. Dell Vostro 1400 Speakers Replacement: 15 단계, 이미지 1/1
    • Remove the left and the right hinge covers.
  16. Dell Vostro 1400 Speakers Replacement: 16 단계, 이미지 1/3 Dell Vostro 1400 Speakers Replacement: 16 단계, 이미지 2/3 Dell Vostro 1400 Speakers Replacement: 16 단계, 이미지 3/3
    • Unplug the WLAN antenna cables.
    • Unscrew the 2mm x 3mm screw.
    • Remove the WLAN card from the motherboard.
  17. Dell Vostro 1400 Speakers Replacement: 17 단계, 이미지 1/1
    • Remove the 2mm x 3mm screw on the media button circuit board.
    • Loosen the media button circuit board and take the antenna cables from under it.
  18. Dell Vostro 1400 Speakers Replacement: 18 단계, 이미지 1/1
    • Unplug LCD cable
    • Lift LCD assembly away from the laptop
  19. Dell Vostro 1400 Speakers Replacement: 19 단계, 이미지 1/2 Dell Vostro 1400 Speakers Replacement: 19 단계, 이미지 2/2
    • Remove the (3) 2.5mm x 5mm top palmrest screws
    • Unplug palm rest cables
  20. Dell Vostro 1400 Speakers Replacement: 20 단계, 이미지 1/2 Dell Vostro 1400 Speakers Replacement: 20 단계, 이미지 2/2
    • Remove the palm rest from the base of the laptop
  21. Dell Vostro 1400 Speakers Replacement: 21 단계, 이미지 1/3 Dell Vostro 1400 Speakers Replacement: 21 단계, 이미지 2/3 Dell Vostro 1400 Speakers Replacement: 21 단계, 이미지 3/3
    • Unplug the audio board cable and the speakers.
    • Remove the 2.5mm x 5mm screw.
  22. Dell Vostro 1400 Speakers Replacement: 22 단계, 이미지 1/3 Dell Vostro 1400 Speakers Replacement: 22 단계, 이미지 2/3 Dell Vostro 1400 Speakers Replacement: 22 단계, 이미지 3/3
    • Remove the (2) 2mm x 3mm screws.
    • Lift the motherboard out of the base and flip it over.
  23. Dell Vostro 1400 Speakers Replacement: 23 단계, 이미지 1/3 Dell Vostro 1400 Speakers Replacement: 23 단계, 이미지 2/3 Dell Vostro 1400 Speakers Replacement: 23 단계, 이미지 3/3
    • Remove the two 2.5mm x 5mm Right and Left speaker screws
    • Lift the speakers away from the base of the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
David Hogg
회원 가입일: 03/20/17
727 평판
안내서 5개 작성하였습니다
Texas Tech, Team S8-G2, Bennett Spring 2017 Texas Tech, Team S8-G2, Bennett Spring 2017 회원
TTU-BENNETT-S17S8G2
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 17
전체 시간: 992
