주요 콘텐츠로 건너뛰기
Dell Vostro 15 3562 Memory Module Replacement
필요한 것
  1. Dell Vostro 15 3562 Memory Module Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Slide the release latch to release the battery [1].
    • Remove the battery from the computer [2].
  2. Dell Vostro 15 3562 Memory Module Replacement, Optical-Disk Drive: 2 단계, 이미지 1개 중 1개
    • Remove the M2L3 screw that secures the optical drive to the computer [1].
    • Using a plastic scribe, push the tab in the direction of the arrow indicated on the chassis. [2].
    • Slide the optical drive out of the computer [3].
  3. Dell Vostro 15 3562 Memory Module Replacement, KeyBoard: 3 단계, 이미지 1개 중 1개
    • Using a plastic scribe, release the five tabs from the slots located above the keyboard [1].
    • Flip the keyboard on the palm rest to access the keyboard connector cable under the keyboard [2].
  4. Dell Vostro 15 3562 Memory Module Replacement: 4 단계, 이미지 1개 중 1개
    • Disconnect the keyboard cable from the system board.
    • Remove the keyboard from the computer.
  5. Dell Vostro 15 3562 Memory Module Replacement, Base Cover: 5 단계, 이미지 1개 중 1개
    • Disconnect the optical drive connector and lift it to remove it from the system board [1].
    • Remove the M2L5 screws that secure the base cover [2].
  6. Dell Vostro 15 3562 Memory Module Replacement: 6 단계, 이미지 1개 중 1개
    • Flip the computer and remove the screws (8 screws - M2.5L8; 3 screws - M2L2; 2 screws- M2L2) that secure the base cover to the computer.
  7. Dell Vostro 15 3562 Memory Module Replacement: 7 단계, 이미지 1개 중 1개
    • Use a scribe to pry the edges of the base cover [1].
    • Lift the base cover and remove it from the computer [2].
  8. Dell Vostro 15 3562 Memory Module Replacement, Memory Module: 8 단계, 이미지 1개 중 1개
    • Pull the clips securing the memory module until the memory module pops up [1].
    • Remove the memory module from the system board [2].
결론
작성자
1다른 기여자 명과 함께
Johnathan Hammond
회원 가입일: 02/28/18
45,555 평판
안내서 408개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,994개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 6
전체 시간: 334
