주요 콘텐츠로 건너뛰기
Dell Vostro 15 3568 Hard Drive Bracket Replacement
필요한 것
  1. Dell Vostro 15 3568 Hard Drive Bracket Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Slide the release latch to release the battery [1].
    • Remove the battery from the computer [2].
  2. Dell Vostro 15 3568 Hard Drive Bracket Replacement, KeyBoard: 2 단계, 이미지 1개 중 1개
    • Release the keyboard by prying on the keyboard release tabs using a plastic scribe [1].
    • Slide and lift the keyboard to access the keyboard connector cable under the keyboard [2].
  3. Dell Vostro 15 3568 Hard Drive Bracket Replacement: 3 단계, 이미지 1개 중 1개
    • Disconnect the keyboard cable from the system board.
    • Lift the keyboard cable to remove it from the computer.
  4. Dell Vostro 15 3568 Hard Drive Bracket Replacement, Base Cover: 4 단계, 이미지 1개 중 1개
    • Disconnect the optical drive connector and lift it to remove it from the system board [1].
    • Remove the screws inside the palmrest [2].
  5. Dell Vostro 15 3568 Hard Drive Bracket Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the screws that secure the base cover to the computer
  6. Dell Vostro 15 3568 Hard Drive Bracket Replacement: 6 단계, 이미지 1개 중 1개
    • Pry the edges of the base cover [1].
    • Lift the base cover and remove it from the computer [2].
  7. Dell Vostro 15 3568 Hard Drive Bracket Replacement, Hard Drive: 7 단계, 이미지 1개 중 1개
    • Disconnect the hard drive cable from the connector on the system board [1].
    • Remove the screws that secure the hard drive assembly to the computer [2].
    • Lift the hard drive assembly away from the computer [3].
  8. Dell Vostro 15 3568 Hard Drive Bracket Replacement, Hard Drive Bracket: 8 단계, 이미지 1개 중 1개
    • Pull the hard drive cable connector to remove it from the hard drive [1].
    • Remove the screws that secure the hard drive bracket to the hard drive [2].
    • Lift the hard drive from the hard drive bracket [3].
결론
작성자
1다른 기여자 명과 함께
Johnathan Hammond
회원 가입일: 02/28/18
45,555 평판
안내서 408개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,994개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 8
전체 시간: 516
