주요 콘텐츠로 건너뛰기
Dell Vostro 1500 Keyboard Replacement
필요한 것
  1. Dell Vostro 1500 Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Make certain the power is off.
  2. Dell Vostro 1500 Keyboard Replacement: 2 단계, 이미지 1/1
    • Press and slide the buttons inward.
  3. Dell Vostro 1500 Keyboard Replacement: 3 단계, 이미지 1/1
    • Slide the battery away from the computer.
  4. Dell Vostro 1500 Keyboard Replacement: 4 단계, 이미지 1/1
    • Remove the battery from the slot.
  5. Dell Vostro 1500 Keyboard Replacement, Keyboard: 5 단계, 이미지 1/3 Dell Vostro 1500 Keyboard Replacement, Keyboard: 5 단계, 이미지 2/3 Dell Vostro 1500 Keyboard Replacement, Keyboard: 5 단계, 이미지 3/3
    • Pry the top panel up from the tab in the upper right hand corner.
    • Run your finger under the panel from right to left to pop it loose.
    • You might have to tilt back the screen if you are having trouble popping it loose.
  6. Dell Vostro 1500 Keyboard Replacement: 6 단계, 이미지 1/2 Dell Vostro 1500 Keyboard Replacement: 6 단계, 이미지 2/2
    • Unscrew the two Phillips head screws.
  7. Dell Vostro 1500 Keyboard Replacement: 7 단계, 이미지 1/2 Dell Vostro 1500 Keyboard Replacement: 7 단계, 이미지 2/2
    • Carefully lift the keyboard away from the computer.
    • Pull the keyboard toward the screen.
    • Do not pull too hard on the keyboard as the connector could be damaged.
  8. Dell Vostro 1500 Keyboard Replacement: 8 단계, 이미지 1/3 Dell Vostro 1500 Keyboard Replacement: 8 단계, 이미지 2/3 Dell Vostro 1500 Keyboard Replacement: 8 단계, 이미지 3/3
    • Lift the blue plastic cover so that is at a 90 degree angle to the keyboard to remove the connection to the keyboard.
  9. Dell Vostro 1500 Keyboard Replacement: 9 단계, 이미지 1/1
    • Pull the connector toward the screen.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Daniel Roskuski
회원 가입일: 10/19/16
219 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 1-3, Catania Fall 2016 UMass Dartmouth, Team 1-3, Catania Fall 2016 회원
UMASSD-CATANIA-F16S1G3
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 8
전체 시간: 975
