소개
This guide shows you how to replace the keyboard. The keyboard is the main input for the laptop. This guide goes through the steps of removing a faulty keyboard.
필요한 것
Pry the top panel up from the tab in the upper right hand corner.
Run your finger under the panel from right to left to pop it loose.
You might have to tilt back the screen if you are having trouble popping it loose.
다른 2명이 해당 안내서를 완성하였습니다.
