필요한 것
Slide the battery lock to the open position.{2}
Slide the battery release latch to the open position. (You may need to hold the battery release latch in the open position while removing the battery.) {3}
Slide the battery out of the battery bay.{1}
Remove the two M2.5 x 8-mm screws that secure the hard-drive compartment cover. {2}
Remove the cover and set it aside. {1}
다른 한 분이 해당 안내서를 완성하였습니다.
