주요 콘텐츠로 건너뛰기
Dell Vostro 1540 Hard Drive Replacement
필요한 것
  1. Dell Vostro 1540 Hard Drive Replacement, Unlocking the Battery: 1 단계, 이미지 1/1
    • Slide the release latches to unlock the battery.
  2. Dell Vostro 1540 Hard Drive Replacement, Sliding the Battery: 2 단계, 이미지 1/1
    • Slide the battery and remove it from the computer.
  3. Dell Vostro 1540 Hard Drive Replacement, KeyBoard: 3 단계, 이미지 1/1
    • Pry up to release the top four snaps securing the keyboard to the computer.
  4. Dell Vostro 1540 Hard Drive Replacement: 4 단계, 이미지 1/1
    • Flip the keyboard over and lay it on the palm rest
  5. Dell Vostro 1540 Hard Drive Replacement: 5 단계, 이미지 1/1
    • Disconnect the keyboard cable from the system board.
  6. Dell Vostro 1540 Hard Drive Replacement: 6 단계, 이미지 1/1
    • Remove the keyboard from the computer.
  7. Dell Vostro 1540 Hard Drive Replacement, Palm Rest: 7 단계, 이미지 1/1
    • Remove the screws that secure the bottom base.
  8. Dell Vostro 1540 Hard Drive Replacement: 8 단계, 이미지 1/1
    • Flip the computer around and disconnect the power board cable (1) and the touchpad cable (2).
  9. Dell Vostro 1540 Hard Drive Replacement: 9 단계, 이미지 1/1
    • Remove the screws that secure the palm rest to the computer
  10. Dell Vostro 1540 Hard Drive Replacement: 10 단계, 이미지 1/1
    • Pry up the palm rest using a plastic scribe to release all the snaps on the bottom, left, and right sides of the palm rest. Once all the snaps have been released, lift up the palm rest from the computer and remove.
  11. Dell Vostro 1540 Hard Drive Replacement, Hard Drive: 11 단계, 이미지 1/1
    • Slide the hard drive and lift it out of the computer.
  12. Dell Vostro 1540 Hard Drive Replacement: 12 단계, 이미지 1/1
    • Remove the screws that secure the hard drive bracket and detach it from the hard drive.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Johnathan Hammond
회원 가입일: 02/28/18
45,034 평판
안내서 408개 작성하였습니다
RampUP America, Inc. RampUP America, Inc. 회원
Community
42 회원들
안내서 1,989개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 7
30일 전: 21
전체 시간: 2,013
